Check engine and traction control light
Discussion in 'Technical Chat' started by MIAtaco, Jan 20, 2013.
  1. Jan 20, 2013 at 12:56 PM
    MIAtaco
    MIAtaco [OP] Well-Known Member
    Brian
    Miami FL
    2010 tacoma base lifted
    2.75" front lift 2.5" rear, pro comp es3000 rear shocks w/ orange shock boots, custom exhaust, k&n cold air intake, 20" led light bar behind grill, aftermarket grill, T-rex3 eyelids, pioneer HD radio
    I recently had to hit my brakes pretty hard and the tires skidded slightly and then my check engine and traction control lights came on and is throwing a catalyst function code is coming up. Any idea what's going on?
  2. Jan 21, 2013 at 8:26 AM
    Vstrom30
    Vstrom30 Well-Known Member
    Midwest
    Tacoma Access Cab 4x4
    It may just be a coincidence that the CEL came on soon after you hit the brakes. Those lights all usually come on in conjunction with each other because when there is an engine fault, the ECM sends a code to the ABS/TRAC/VSC computer telling it to stand down, and this code is C1201, unless there are additional things going on with the ABS. Now we need to know which catalyst is below threshold. With yours being a 2010, the catalyst may still be covered under 8 year/80k emissions warranty.
  3. Jan 21, 2013 at 8:39 AM
    MIAtaco
    Brian
    Miami FL
    the code thats popping up is a p0240
  4. Jan 21, 2013 at 8:53 AM
    Vstrom30
    Midwest
    I'm assuming you mean P0420, and your truck only has 1 bank. There is a good possibility that the catalyst is weak. The other possibilities are a leak in the exhaust pipe, or faulty A/F or o2 sensors. If you are under 80k miles, and it needs a cat, it should be free replacement due to federally mandated emissions warranty.
  5. Jan 21, 2013 at 8:55 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    you sure it is p0240 ?
    P0240 Turbocharger Boost Sensor B Circuit Range/Performance
    if it is p0420, then
    a) most likely, the o2 sensor itself is on it's way out. they have a finite life anyway,
    or it's clean air sample port is dirty or has been underwater....
    b) less likely, the cat is on it's way out. but cats last far longer than o2 sensors, generally
  6. Jan 21, 2013 at 11:33 AM
    Vstrom30
    Midwest
    Also, how custom is your exhaust? Any possibilities of leakage?
  7. Jan 21, 2013 at 1:36 PM
    MIAtaco
    Brian
    Miami FL
    Yeah p0420 and there is a small leak but not anywhere near an oxygen sensor and the cat is only 3 months old
  8. Jan 21, 2013 at 1:47 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    p0420 sniffs the results of the cats, and that is it's only function
    fuel and engine control comes from the front sensor before
    the first cats
    anyhow
    I will bet that the o2 sensor itself is toast. need the exact same denso part number
    for best results (aftermarket sensors are a crap shoot, might still throw a code)
    so...
    if no air/exhaust leaks between the first sensor, the cats, and this o2 sensor,
    I'd bet it is the sensor itself, 150 bucks give or take
  9. May 22, 2023 at 1:44 PM
    microsnook
    microsnook Well-Known Member
    '20 TRD OR MGM MT
    P0101 is the code. Looks to be MAF related. There is hesitation on acceleration as well so definitely adds up. Should I hit it with some contact cleaner and see if it fixes it? Or replace the harness entirely? thanks
  10. May 23, 2023 at 10:31 AM
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    I'd clean it first just to confirm it is bad.
    Would suck to buy a new one if that's not the problem.
    microsnook likes this.
  11. Jun 1, 2023 at 2:47 PM
    microsnook
    '20 TRD OR MGM MT
    Can I use contact cleaner ?
  12. Jun 2, 2023 at 7:46 AM
    MR5X5
    MR5X5 Well-Known Member
    MAF specific cleaner for the MAF. Contact cleaner for the O2 connector.
