Check Engine, Catalytic converter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by night_angel, Jul 13, 2010.
  1. Jul 13, 2010 at 2:08 PM
    night_angel
    night_angel [OP] Well-Known Member
    Thomas
    Asuncion-Paraguay
    05 TRD Sport
    ECU FT500, JBA Headers, 100% Offroad
    so, I remove the four catalysts, and now the light "check engine" jump a error "catalyst system efficiency below threshold (bank 1) and (Bank 2)
    CODE : P0420 (bank 1)
    CODE : P0430 (bank 2)
    here we do not need a catalyst, so, what can I do, to avoid this error"check engine light"?
    now I feel much more power...& and the engine goes smoother...
    thanks in advance for the help..:)
  2. Jul 13, 2010 at 2:09 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well...if you got rid of the front ones as well...which it seems you have.....you may as well just cover the light up, because im not sure there is a way to trick the cel after you have removed all 4 cats.
  3. Jul 13, 2010 at 2:17 PM
    night_angel
    Thomas
    Asuncion-Paraguay
    05 TRD Sport
    no, now there are no restrictions on the exhaust gases..., the catalystdoes help for performance, is a brake for the engine..
    thanks for the tip from O2 Simulator...
  4. Jul 13, 2010 at 2:21 PM
    Hajro
    Hajro Member
    Hajrudin
    Jacksonville, FL
    07 trd sr5 sport
    Thats badass. Could you post a clip of how your truck sounds without the cats on?
  5. Jul 13, 2010 at 2:33 PM
    night_angel
    Thomas
    Asuncion-Paraguay
    05 TRD Sport
    is correct that, but I have the muffler, the make a back pressure , and I have to put another pre-muffler, because the sound is very loud and tinny..., with that fix I the back pressure ,what the engine need...
    Here we do not have a dyno .. is very difficult .. the only Dyno, is at 500km from here, and is in Brazil and is 4x2 dyno.., not a 4x4 dyno...
  6. Jul 13, 2010 at 2:43 PM
    night_angel
    Thomas
    Asuncion-Paraguay
    05 TRD Sport
    Is was only a comment that I put that... I know that I not need a 4x4 dyno for that.., I work with drag cars here...and Is always a problem, without a 4x4 dyno...
