Check engine codes p0136 and p0138
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jstem4, May 23, 2014.
  1. May 23, 2014 at 8:12 PM
    jstem4
    jstem4 [OP] Member
    Quebec
    2010 Tacoma 2.7
    Hi, for about 3 months I've been getting the p0136 and po138 at the same time. Both codes are 02 sensor related(Bank1 sensor2), this sensor is located after the catalytic converter.
    My truck is a 2010 Toyota Tacoma access cab 2.7L 4x4 with 92000 KM (around 57000 miles) on it. At first I though the problem was the sensor, so i replaced the sensor after the catalytic converter. That didn't do it, both the codes still come on. All the wires seem to be correct... I mean the truck is barely 4 years old what could it be?
    Is there anyone who had this issue?
    Here are some pictures:
    The first one is the dash with the check engine light on and the ESp light.
    The others are some print screen I made when i was on my OBD software. You can see all the specs when the truck is running. Also i took a print screen of the sensor when i give some trottle to the engine on neutral, i voltage seem to go below 0 or at 0 volts.
    Is this normal?
    Any help would be extremely appreciated.
    Thanks
    Julien
  2. May 23, 2014 at 9:40 PM
    gearcruncher
    Canadain bumper technician
  3. May 23, 2014 at 9:46 PM
    jstem4
    jstem4 [OP] Member
    Quebec
    2010 Tacoma 2.7
    Wow thanks, what is this document?
  4. May 23, 2014 at 10:10 PM
    gearcruncher
    its a diagnostic procedure directly from Toyota explaining how to fix your problem
  5. May 23, 2014 at 10:16 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
  6. May 23, 2014 at 10:20 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Your emissions system have a 80k mile warranty per federal law. Take it to the dealer and stop screwing with it.
  7. May 23, 2014 at 10:24 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    He's in that Canadia place.
  8. May 24, 2014 at 5:12 AM
    jstem4
    jstem4 [OP] Member
    Quebec
    2010 Tacoma 2.7
    I called the dealership and they told me it was not covered.
  9. May 24, 2014 at 5:17 AM
    jstem4
    jstem4 [OP] Member
    Quebec
    2010 Tacoma 2.7
    Thanks for the link, if i cannot find the problem I will look into this simulator. Is there anyway to diagnostic a bad cat?
  10. May 24, 2014 at 7:56 AM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    If your OBD/CAN scanner has an "advanced" function to get the Toyota codes you can tell that way, or you can pay the dealer to diagnose it.
  11. May 24, 2014 at 10:06 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Damn them!
  12. May 24, 2014 at 10:17 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Check your owners manual / warranty guidelines, I'm pretty sure you still have emissions component coverage. Don't take the word of some uninformed service writer unless you want the short end of the stick. Heck, you should still be covered under the 5yr/100,000 km powertrain warranty.
  13. May 24, 2014 at 10:20 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Theres some HOT girls in canada
  14. May 24, 2014 at 1:59 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
  15. Jun 2, 2014 at 2:20 PM
    jstem4
    jstem4 [OP] Member
    Quebec
    2010 Tacoma 2.7
    I noticed today that my 02 sensor temp doesn't go over 200 degrees celsius (392 farenheit)
    . Could this be the problem?
  16. Jun 2, 2014 at 11:49 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    if you only worried about getting an inspection sticker or something like that, emissions stuff. if you have an OBD reader, goto the inspection place, right bfore you go inside, read the codes, then select reset codes, then have them do inspection, it take a while of driving for the codes to register again and trigger any dash lights and stuff...
  17. Jan 20, 2015 at 1:37 PM
    Kbor
    Kbor New Member
    Nova Scotia
    2012 2.7 SR5
    Hi, I have a 2012 2.7 with 63000km and getting code P0136 only. I replaced the rear O2 sensor, still getting same code. Anybody have any suggestions?
    Thanks,
    Kevin
  18. Jan 20, 2015 at 2:28 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    P0136 means the sensor has low voltage, and is "running lean". Double check the connector, the wires leading to it, and pull your ecu fuse or battery cable to let the computer reset. If all of that is good, it could be a bad cat, or even the upstream O2 sensor.
  19. Jan 20, 2015 at 7:48 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Yes, you have powertrain and emissions warranty at that age and mileage, so take it to your dealer.
  20. Jan 24, 2015 at 12:13 PM
    Kbor
    Kbor New Member
    Nova Scotia
    2012 2.7 SR5
    Unfortunately Toyota doesn't cover O2 sensors after 60000km. Going to check connector/wires tonight.
