Check engine codes p0136 and p0138
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jstem4, May 23, 2014.
  1. Mar 29, 2015 at 4:11 PM
    jstem4
    jstem4 [OP] Member
    Quebec
    2010 Tacoma 2.7
    So i still have this problem on my tacoma... but i no longer have the p0136 only the p0138.
    I know to 02 sensor is not the problem cause i got two of them that do the exact same thing :
    they stay at around 0.835 V and don't move much. When i release the throttle they go down to around 0.15V and slowly go back to 0.835V.
    I only get the p0138 code when i ride at the same speed for around 2-4 minutes because the sensor output is around 0.835V.
  2. Mar 29, 2015 at 5:38 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Did you do anything I suggested earlier in the thread? Upstream o2 sensor replaced yet?
  3. Mar 29, 2015 at 7:41 PM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    your a/f sensor is bad and its thinking the 02 sensor is bad cause the af sensor is giving the wrong readings. if you have a high voltage code start with the af sensor first
  4. Mar 30, 2015 at 12:42 PM
    jstem4
    jstem4 [OP] Member
    Quebec
    2010 Tacoma 2.7
    I ordered one and will try it! I will keep you guys tuned!
    Thanks
    Jstem4
  5. Apr 8, 2015 at 4:08 PM
    jstem4
    jstem4 [OP] Member
    Quebec
    2010 Tacoma 2.7
    Hey guys, so i ordered a air fuel sensor (bank 1) from ebay. The guy i bought it from said it was the Denso 934-9050 but when i received it today I founded out that the sensor is actually a 89497-07040. Will this sensor work? Why is it so much cheaper than the 89497-04050(tacoma 2.7 Oem) ?
    Can this break anything in my truck?
    Should i install it or just return it to buy a 89497-04050?
    thanks jstem4
  6. Apr 22, 2015 at 8:24 PM
    jstem4
    jstem4 [OP] Member
    Quebec
    2010 Tacoma 2.7
    Hey guys,
    I received my air fuel sensor and installed it. I did not get the code back yet, it's been a week. I Guess that was my problem, the front air fuel sensor.
    Thanks a lot for your tips!
    But I noticed something weird on my 02 sensor(bank 1 sensor 2). When the truck is all warmed up at idle the output voltage stays at around 0.835v. It does not fluctuate. Even sometimes when i drive the output voltage stays at a reading without moving, and sometimes it works correctly. I am guessing the this sensor is also bad, but i just replaced it with a new one 8 months ago. Maybe i destroyed it with running the truck rich for all that time?
    Can it be something else or is it the 02 sensor?
    Thanks for your help !
    Jstem4
  7. Apr 22, 2015 at 9:14 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
  8. Apr 23, 2015 at 6:43 AM
    jstem4
    jstem4 [OP] Member
    Quebec
    2010 Tacoma 2.7
    Maybe my cat is toasted? I've been running for a long time with a bad air fuel sensor...
  9. Apr 23, 2015 at 9:32 AM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    I doubt it, they are pretty tough. I ran leaded race gas mixed with two stroke oil in my truck once, cats were still ok.
  10. Apr 23, 2015 at 4:14 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yes, where did you read the temp?
  11. Apr 23, 2015 at 4:18 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    The voltage should vary from 0 volts to 1 volt and be pretty active. Running rich should not damage it how do you know it was rich?
