Check Engine Codes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Freeheelbillie, Mar 19, 2019.
  1. Mar 19, 2019 at 6:02 PM
    Freeheelbillie
    Freeheelbillie [OP] Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    Dummy light came on, still running like a top though. 2007 V6 TRD
    Pulled the Code P0452 - Emissions System Pressure, what's this about...Fuel Tank Pressure Sensor is my best guess.
    Stored Codes PO100, P0102 and P0103 all Airflow related ??
    and a P0300 random misfire...likely time to change the plugs.
  2. Mar 19, 2019 at 8:26 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The pcm uses the fuel tank pressure sensor for information when performing various evap system functions, like purging and leak checking.
    The p0100/102/103 codes are MAF sensor related, like it thinks the connector is unplugged.
    P0300 means the pcm knows it has a misfire, it just cant pin down which specific cylinder.
    blu92in99 and Freeheelbillie[OP] like this.
  3. Mar 21, 2019 at 3:15 AM
    Freeheelbillie
    Billie
    Saint Clair, MI
    So the fuel tank pressure sensor code and the P0100/102/103 codes are directly related/linked to the same issue?
  4. Mar 21, 2019 at 5:37 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Probaby not related.. unless those circuits share a common fuse that blew.
  5. Mar 21, 2019 at 7:51 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  6. Mar 23, 2019 at 9:35 AM
    Freeheelbillie
    Billie
    Saint Clair, MI
  7. Jan 11, 2020 at 3:54 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    I like to update when I finally get nagging issues squared away. Also, see the related post, https://www.tacomaworld.com/threads/ghost-in-the-machine.639805/ and here https://www.tacomaworld.com/threads/evap-check-engine-codes.636808/#post-21931473
    Through some trial and error, I was able to track down the ABS and Brake light issue, which wasn't another faulty wheel speed sensor as suspected. It was was actually a worn wire (in about the middle of the cab under the truck) that had chafed and lost connection. While I was in there I found more than one suspect wire, repaired (NASA wire splice technique). The check engine code went away too! I have run about 600 miles and it has not returned. Oh, and I change all 6 plugs awhile back.
    :yes:
    TnShooter likes this.
