Check engine fault code
Discussion in '1st Gen. Tacomas (1995-2004)' started by Aquatic Tacoma, Jun 17, 2017.
  1. Jun 17, 2017 at 2:52 PM
    Aquatic Tacoma
    Aquatic Tacoma [OP] Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    2003 3.4 Double Cab. Check engine light is on. No others. Popped into Advanced Auto Parts store, reader came up with "open in stop light switch circuit". All lights work fine. I have done no changes or mods on truck. Ran reader 3 times, once after disconnecting and reconnecting battery. Code is on as soon as key is turn on. Ideas? Thanks.
  2. Jun 17, 2017 at 2:54 PM
    Clearwater Bill
    Billy
    Largo Florida
    What is the actual code number?
  3. Jun 17, 2017 at 2:57 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Check "stop" fuse 1st, then Check Ig1 fuse
  4. Jun 17, 2017 at 2:59 PM
    IronPeak
    AuggieX
    Back to Back
  5. Jun 17, 2017 at 8:20 PM
    Aquatic Tacoma
    Odessa, Fl.
  6. Jun 17, 2017 at 8:26 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    The brake light switch has 4 wires that go to it and 2 circuits. I believe on is for the computer.
  7. Jun 17, 2017 at 8:31 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Diag. info attached
  8. Jun 18, 2017 at 3:11 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Remember a code is the complete circuit for what ever switch sensor etc.
    So the complete circuit needs to be checked along with the ECM
  9. Jun 18, 2017 at 4:22 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    The first thing you should do is this:
    Check voltage at the "STP" wire at the ABS module with the key on and someone stepping on the brake.
    I saw this problem a lot while working at Lexus. The brake switch is probably bad.
  10. Jun 29, 2017 at 8:04 PM
    Aquatic Tacoma
    Odessa, Fl.
    Update. Went to my buddy's repair shop. He used his "pro" reader. It called out front o2 sensor. R&r'd sensor with new. All works fine, no check engine light.
  11. Jun 29, 2017 at 11:24 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    What was the code number you were getting to start with?
  12. Jun 30, 2017 at 11:02 AM
    Aquatic Tacoma
    Odessa, Fl.
    Code reader at Advanced Auto Parts read c1249. Reader at my buddy's shop said fwd o2 sensor.
