Check engine flash, engine sputtering
Discussion in 'Technical Chat' started by Raiden06BSP, Dec 21, 2012.
  1. Dec 21, 2012 at 3:44 PM
    Raiden06BSP
    Raiden06BSP [OP] Well-Known Member
    New York
    07 DLB Cab SR5 4x4
    URD 3" catback, NST manifold spacer, Leer 100r cap, Thule roof rack, DTLT headers, URD calibrator, 885's, OME sport front and rear shocks, 5mm trim packer, 2" AAL, OME sway bar relocate, 265/75/16 Duratracs
    2007 tacoma v6. Went to pass a snow plow truck. The truck kicked down 2 gears, hug in gear for a second then shifted and the check engine light started flashing and the truck fell on its face. No codes or power. It started sputtering and shaking. From what I've read it might be the plugs or the maf sensor needing to be cleaned. I'm about 4 hours from home so I'm gonna make the trip home in a couple days. Looking to see if anyone has had the same issue and what you did to fix it or any ideas that it might be. Thanks
  2. Dec 21, 2012 at 3:58 PM
    Fast_Freddy
    Fast_Freddy Well-Known Member
    99 Black PreRunner
    ome suspension lift, Borla catback exhaust, S-runner bucket seats
    Check engine light flashing indicates a severe misfire...youre in danger of melting your cats.
  3. Dec 23, 2012 at 5:30 AM
    Raiden06BSP
    New York
    07 DLB Cab SR5 4x4
    After looking over the truck a little bit. I found that the plug going to the number one coil pack was not in all the way. I pressed on it and it clicked in. Hope that was my problem.
