Check engine light 09 Tacoma
Discussion in 'New Members' started by RainDean, Dec 23, 2023.
  1. Dec 23, 2023 at 2:15 PM
    RainDean
    RainDean [OP] New Member
    Hey friends,
    09 Tacoma … check engine light was on when I started her up this morning ( wasn’t on last night ) Code P0607— we had a good amount of snow thru the night and check light came on once before months ago when we had heavy rain.. coincidence? I cleared the code and has not come back, any help much appreciated!
  2. Dec 23, 2023 at 6:57 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    It's a PCM internal error code if it's not persistent I wouldn't worry too much about it although you may get your battery checked and make sure your battery cables are clean and tight as low battery voltage can cause those types of codes to set.
    Cody901 likes this.
  3. Dec 23, 2023 at 9:05 PM
    Cody901
    Cody901 Member
    Cody
    Memphis, TN
    2023 Magnetic Gray Limited
    My '99 had the check engine light come on periodically for about 6 months. Couldn't ever figure out why, until I eventually found out it was from an exposed wire in the ground wire for the battery.
  4. Dec 24, 2023 at 3:12 AM
    RainDean
    Thanks guy’s, battery terminals are clean, I’ll
    Check the voltage tomorrow, seems odd to only happen when there’s a lot of moisture in the air
    Cody901 likes this.
  5. Dec 24, 2023 at 3:08 PM
    Cody901
    Cody901 Member
    Cody
    Memphis, TN
    Let us know when you find out. Hopefully it's quick and simple.
    RainDean[QUOTED][OP] likes this.
  6. Dec 24, 2023 at 3:23 PM
    RainDean
    Thanks, all seems to be good … maybe just a quirky thing but seems to happen every few months with significant moisture in the air ..thanks!
