Check Engine Light 97 2.4
Discussion in '1st Gen. Tacomas (1995-2004)' started by gray97taco, Sep 24, 2023.
  1. Sep 24, 2023 at 2:32 PM
    gray97taco
    gray97taco [OP] Member
    97 Taco Raptor
    97 tacoma 2.4 raptor lined gray
    About a week ago my check engine light came on. The truck gets to about 1000 rpm’s at first but warms up a bit and will get to about 3000 in its gear and just lose power and have trouble accelerating. You can also smell a slight gassy smell. the code reader at first read p0135 and p0125, so we replaced the o2 sensor and coolant temp switch. The light never went off but now the ob2 reader just reads a code for not being able to connect. we also tried replacing the fuel filter and checked spark plugs and wires with no luck. i have no clue what it could be help
    I uploaded a video of it on youtube here
    https://youtube.com/shorts/tw1QAvB3hLI?si=huvIuYwlAy7MGuS_
  2. Sep 24, 2023 at 2:44 PM
    Clearwater Bill
    Billy
    Largo Florida
    Did you clear the old codes after the first work was done?
  3. Sep 24, 2023 at 2:46 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    So the scan tool can not connect to the ECM to read codes?
  4. Sep 24, 2023 at 3:05 PM
    gray97taco
    97 Taco Raptor
    it soemtimes will and sometimes won’t i really don’t get it either the one time i did get it to connect it read those two codes
  5. Sep 24, 2023 at 3:06 PM
    gray97taco
    97 Taco Raptor
    no i never did
  6. Sep 25, 2023 at 6:18 AM
    Taco_Love
    Taco_Love Well-Known Member
    99 reg cab 4x4
    If you unhook the battery it'll clear the codes for you :)
  7. Sep 25, 2023 at 7:58 AM
    Glamisman
    Glamisman Well-Known Member
    In the engine compartment locate the fuse box and find the OBD fuse and replace it with the same amperage. I have seen cracked fuses do the same thing. You could waste a-lot of time looking for an intermittent.
    There are what are called hard codes and soft codes, hard codes require that you manually clear them, soft codes will self clear.
    Look at the wiring diagram and see what fuses are used and check them first.
