Check Engine light after intake/exhaust install?
Discussion in 'Technical Chat' started by KMANAZ, Mar 12, 2010.
  1. Mar 12, 2010 at 2:43 PM
    KMANAZ
    KMANAZ [OP] New Member
    Kurt
    ARIZONA
    04 Tacoma Double Cab
    3" lift, wheels/tires, K&N FIPK, Magnaflow catback
    Just installed a K&N cold air intake and Magnaflow cat-back exhaust on my 2004 3.4L Tacoma. Now the check engine light is on. I had it scanned - getting a catalyst error from the O2 sensor (too much unburned fuel in the exhaust). Anyone else have this problem? Suggestions (reflash ECU?). Any help would be appreciated since the other alternative is a new catalyst at about $800.00.
    Thanks!
  2. Mar 12, 2010 at 2:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    What was the actual code?
  3. Mar 12, 2010 at 2:49 PM
    Brunes
    Brunes abides.
    Rotorhead
    I would check your paperwork about the catalyst thing- The warranty on the emissions parts is extended on a lot of cars (My scion had a 8 years/80K emissions warranty....)
  4. Mar 12, 2010 at 2:49 PM
    Brunes
    Brunes abides.
    Rotorhead
    And what Chris said....
  5. Sep 7, 2010 at 6:53 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    p0420 im having the same problem
  6. Sep 8, 2010 at 8:34 PM
    Barnone
    Barnone Guest
    KMANAZ,
    You probably ought to put it back to stock before you go in for the emission's warranty.
    [FONT=Verdana, Arial, Helvetica, sans-serif]Emissions[/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]8 years or 80,000 miles [/FONT]
  7. Sep 8, 2010 at 8:57 PM
    jesus
    jesus Well-Known Member
    jesus
    bakersfield
    K&N ram intake & doug exs.
    look up the new magnaflow they have a blot on for about $300-$450 but ya got to do some shoping around and there cali ok I forgot where ya where at if not in cali then go on ebay tons for under $300 and sometimes under $200
  8. Sep 11, 2010 at 7:55 AM
    malander
    max
    01 limited trd 4x4
    i wouldnt get a new cat yet unless you are positive thats the problem it could be a bad o2 sensor, exhaust leak, or the cat but make sure before you spend too much when the fix could be simple
