Check engine light and Trac Off Light
Discussion in '3rd Gen. Tacomas (2016-2023)' started by darron1117, Jan 23, 2024.
  1. Jan 23, 2024 at 4:51 PM
    darron1117
    darron1117 [OP] Well-Known Member
    D
    2019 Toyota Tacoma TSS (Black)
    Hello all,
    I have a 2019 2.7 Tacoma w/45k miles. Cranked it up this evening and the check engine light is on and a little while later the Trac off light joined it, so both are on now. Can't turn traction on using button. Will take it to dealer, but what could this be?
    Thanks in advance.
  2. Jan 23, 2024 at 4:53 PM
    BlackCat81
    BlackCat81 Well-Known Member
    2023 Ice Cap TRD OR
    Trac light accompanies the check engine light. It’ll have to be scanned for codes before anyone can help you without totally guessing.
  3. Jan 23, 2024 at 4:55 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Look to see if you have rodent damage in the engine wire harness. It's pretty common.
  4. Jan 23, 2024 at 4:56 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    There's over 200 possible codes that can turn the check engine light on so take your pick, Trac Off light will always accompany the Check Engine light on Toyota.
    Make sure your gas cap is on tight, beyond that without the code(s) it's anyones guess.
    Chew likes this.
  5. Jan 23, 2024 at 5:57 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Does the Trac Off light intermittently go off and back on?
  6. Jan 24, 2024 at 12:56 AM
    darron1117
    D
    Going to get it scanned. Trac light stays on.
  7. Jan 24, 2024 at 1:18 AM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
  8. Jan 24, 2024 at 9:21 AM
    darron1117
    D
  9. Jan 24, 2024 at 9:22 AM
    darron1117
    D
    As I drive it intermittently does go on and off.
  10. Jan 24, 2024 at 9:35 AM
    TA2016
    Oregon
    When I was trying to find a locking gas cap that would not throw a CEL light, that was the symptoms I had. Check Engine light would be solid lit and Trac Off light would go on and off intermittently. Once my gas cap was sealing it took a couple of trips for the CEL light to reset or I could clear it with my scan tool.
  11. Jan 24, 2024 at 9:47 AM
    TA2016
    Oregon
    If you do need a new gas cap (locking or non-locking), be aware some gas caps do not seal properly. Check out post #61 on this link. My locking gas cap looks like the one on the left. No CEL light in 8 years. I make sure it clicks 3 times after each fill up.
    https://www.tacomaworld.com/threads/locking-gas-cap.750710/page-4
  12. Jan 24, 2024 at 9:56 AM
    darron1117
    D
    I was on the way to get it scanned and stopped for gas. Put cap back on and light went out. Going to get OEM from dealer. Thanks for your help. Have a great day!!!
    Canadian Caber, Chew and TA2016 like this.
