check engine light and traction light on with O2 sensor code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by scrimmy, Oct 20, 2020.
  1. Oct 20, 2020 at 2:25 PM
    scrimmy
    scrimmy [OP] New Member
    good afternoon, i have a CEL with O2 sensor (bank 2 sensor 2) as well as traction light. It appears the Traction control is non-functioning. Do these issues go hand in hand? Can i assume if i change out the O2 sensor the TC will function normal?
    2010 Tacoma TRD Sport V6
    213k km's. (133k mi)
  2. Oct 20, 2020 at 10:12 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Since the traction control may intervene using engine overrides it is often disabled with engine trouble codes.
  3. Oct 20, 2020 at 10:15 PM
    Bishop84
    Bishop84 Well-Known Member
    Yes, it will be resolved with the replacement. If you can read the code you should be able to clear it to see that the o2 code is causing the traction light as well.
  4. Oct 21, 2020 at 6:18 AM
    scrimmy
    thanks to Bishop84 and ShimStack for your replies. O2 sensor on order. Dealership here in Alberta wanted $270 for the downstream sensor. Rock Auto was 52$ plus shipping. Amazon $63 all in. Shocker.
