Check Engine Light Blinks when I start the Truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gumby002, Jun 21, 2017.
  1. Jun 21, 2017 at 9:58 AM
    gumby002
    gumby002 [OP] Member
    2013 Tacoma - Black
    none...so far
    Greetings,
    My Maint Reqd light blinks 4 or 5 times (and then turns off) after the other idiot lights turn off. Is this normal for a 2013 PreRunner?
  2. Jun 21, 2017 at 9:59 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    You're coming up on an oil change.
    It will flash 5 times and then turn off. When you hit the 5k interval it'll stay lit until reset.
    You can find reset instructions online with a quick Google. Takes 5 seconds. Can't remember sequence offhand.
  3. Jun 21, 2017 at 10:05 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    The check engine light or the maint light? Two totally different lights
  4. Jun 21, 2017 at 10:06 AM
    eon_blue
    Azusa, CA
    The check engine light blinks for maintenance? I thought there was a separate maintenance light for that?
    Not saying it isn't true (I don't have a 2nd gen after all), just seems odd considering a continually blinking CEL is usually indicative of a major malfunction. I'd be sweating bullets looking at that light blinking hoping it would go off after a few seconds, lol.
  5. Jun 21, 2017 at 10:06 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Are you sure it's the check engine light?
  6. Jun 21, 2017 at 10:09 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    ChadsPride likes this.
  7. Jun 21, 2017 at 10:19 AM
    gumby002
    2013 Tacoma - Black
    none...so far
    my apologies...its the Maint Reqd light
    JimboAnz likes this.
  8. Jun 21, 2017 at 10:33 AM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    In that case, it's nearing time to change your oil if you're planning on changing every 5k. You can click on @JimboAnz's link above for instructions on how to turn it off once you do change it.
  9. Jun 21, 2017 at 10:46 AM
    gumby002
    2013 Tacoma - Black
    none...so far
    Thanks y'all. I was hoping it wasnt something bad.
  10. Jun 21, 2017 at 10:48 AM
    T4RFTMFW
    Check engine light doesn't blink, fellas.
    That was a clue.
    OR WAS IT?
    Bebop likes this.
  11. Jun 21, 2017 at 11:27 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Don't feel bad, the first time my Maint Req light came on I immediately pulled over and bought a code reader. I was very confused for awhile when it said my truck was healthy.
    Did this change at some point? I know at some point a flashing OBDII CEL meant that something was very wrong and potentially causing damage to the cats.
  12. Jun 21, 2017 at 11:29 AM
    T4RFTMFW
    Would assume any fault that would trigger a CEL wouldn't let the CEL disappear after 5 blinks.
  13. Jun 21, 2017 at 11:52 AM
    Bebop
    Nick
    Check engine light blinks if it's misfiring
    T4RFTMFW[QUOTED] likes this.
  14. Jun 21, 2017 at 11:53 AM
    T4RFTMFW
    Interesting.
    I had a misfire on my 2013 many times and don't recall that. Was 4 years ago, so I have an excuse. :anonymous:
  15. Jun 21, 2017 at 11:55 AM
    Bebop
    Nick
    Usually when it's bad enough for the ecu to start thinking worse case scenario and start dumping fuel. Cat damage will occur. Blinking check engine light means shut it down dumbass!! A minor misfire won't make the engine light blink. I'm sure somebody here knows the number of how many misfires it takes to get the light to blink.
    Partzguy and T4RFTMFW[QUOTED] like this.
