Check Engine Light Came on at 5K Miles
Discussion in 'Technical Chat' started by Rhody76, Apr 26, 2011.
  1. Apr 26, 2011 at 3:13 PM
    Rhody76
    Rhody76 [OP] Well-Known Member
    Rhode Island
    2011 SR5 DCLB 4x4
    Rear leaf TSB, Bilstein 5100s set at 1.75",1" blocks, UWS low profile toolbox in black, husky liners, tint, LED interior and reverse lights, yellow fogs
    My truck just hit 5K miles and I noticed the check engine light is on. I had the first oil change done about a month ago at the dealer. Could it be to tell me its time to change the oil even though it already been done or is it probably something else?
  2. Apr 26, 2011 at 3:15 PM
    nobody4343
    nobody4343 Well-Known Member
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    hid headlights, black spyder jdm headlight housings, black jdm led spyder taillights, full led bulb swap, hid foglights, 3 inch pro comp lift, black out emblems, two 4 inch hid lights mounted behind the satoshi, wade vent visors, black westin nerf bars, black stubby antenna, k and n cold air intake, flowmaster delta 50 dual exhaust custom black tips, color matched satoshi grill with custom emblem
    Is it the check engine or service engine soon light
  3. Apr 26, 2011 at 3:17 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    x2... Check Engine or Maintenance Required?
  4. Apr 26, 2011 at 3:18 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Did they reset the oil change reminder? Press the odometer button in and hold and turn on ignition, do not turn on engine. There will be 6 little bars and it will count down to zero and that means its reset.
  5. Apr 26, 2011 at 3:19 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    that or check your gas cap. those are the 2 things that first pop into my mind
  6. Apr 26, 2011 at 3:20 PM
    nobody4343
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    X2
  7. Apr 26, 2011 at 6:58 PM
    Rhody76
    Rhode Island
    2011 SR5 DCLB 4x4
    Its the "maintenance required" light. I'm hoping is just the gas cap or oil change thing
  8. Apr 26, 2011 at 7:01 PM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    They didn't reset your maintenace required light when you got you oil changed. It is set to go off at 5k intervals.
  9. Apr 26, 2011 at 7:05 PM
    seksilumpia
    seksilumpia Well-Known Member
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    Performance mods: TRD CAI, AFE throttle body spacer, Doug Thorley headers, TRD exhaust. Cosmetic mods: HID 10k head+3k fog lights, BHLM, T-rex 2 eyelids, billet grill (5 piece), 20% front window tint, 4% back window tint, tinted 3rd brake light, altezza tail lights, LED license plate lights, door skid protectors, slotted drilled rotors,plasti dip rims,painted rotor and drums. Interior mods: TRD seat covers, LED map and dome lights, 2 kicker 10' w/ 500 watt amp, pioneer door speakers,and Pioneer AVIC X930BT.
    i think its the service light that turned on..they want you to have your 5k service on time so it comes on a little before 5k mi.
  10. Apr 26, 2011 at 7:16 PM
    Rhody76
    Rhode Island
    2011 SR5 DCLB 4x4
    cool thats easy. hopefully thats all it is
  11. Apr 26, 2011 at 7:26 PM
    nobody4343
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    That should do its gnna happen every 5000 miles so get use to it
  12. Apr 30, 2011 at 2:44 PM
    Rhody76
    Rhode Island
    2011 SR5 DCLB 4x4
    I tried the procedure to reset the maintainence required light but it wont go off. I select trip a with the ignition off then turn the ignition on but not starting the motor while holding the odometer button in. I never saw the bars counting down and the light did not go off. how long do i hold it in? Thanks
  13. Apr 30, 2011 at 2:54 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Try doing it from the odometer position instead of trip a.
