Check engine light came on, never happened before...?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by flyboy718, Mar 20, 2017.
  1. Mar 20, 2017 at 11:49 AM
    flyboy718
    flyboy718 [OP] Well-Known Member
    Dallas
    05 Prerunner 4 cyl manual 226,000 miles
    I have a 2005 PreRunner. It's original to me with 190,000 miles. Never had the check engine light come on. All the book says is to take it to a Toyota Dealer.
  2. Mar 20, 2017 at 11:54 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Let us know what they say...?
  3. Mar 20, 2017 at 11:56 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Take it to an Autozone or similar to get the CEL code. If the CEL is flashing you have bigger problems.
    TexasWhiteIce likes this.
  4. Mar 20, 2017 at 11:58 AM
    flyboy718
    Dallas
    Oh boy. Let's hope that is not the case, I normally do not have the best luck.
  5. Mar 20, 2017 at 12:00 PM
    eon_blue
    Azusa, CA
    He means if it's currently flashing. Is the check engine light on solid or does it flash? Flashing indicates a bigger issue and you should try not driving it if that's the case.
    wilcam47 likes this.
  6. Mar 20, 2017 at 12:03 PM
    wilcam47
    Will
    Bourbon state
    If its seems to be running ok, I would suspect something minor like an O2 sensor. But cant start narrowing it down with at least a CEL code.
  7. Mar 20, 2017 at 12:11 PM
    flyboy718
    Dallas
    It is solid. And after driving it to lunch and back nothing seems odd or not normal. Also all my fluid levels are good and the temperature stayed where it always is. Idling fine and no anomolies that I can tell.
  8. Mar 20, 2017 at 12:13 PM
    eon_blue
    Azusa, CA
    Might just be a vacuum leak somewhere or running too lean/rich for some reason. Get the code pulled at any autoparts store and you can post it up here (or google the code) and you'll be able to narrow it down. Even if everything feels normal you don't want to drive around for too long letting it go unresolved as it could turn into a much bigger issue sooner or later.
  9. Mar 20, 2017 at 2:20 PM
    Sugar Silva
    Sugar Silva Well-Known Member
    Dave
    San Diego, CA
    16 Toyota Land Cruiser
    Kings Sliders TRD Rock Warrior Wheels Tint
    This could anything from a loose gas cap to an expensive failure. Chances are, it's nothing big. I think an O2 sensor is a good bet. You can have your codes read by a local parts store and troubleshoot it yourself or take it to a dealer or shop of your choice for a proper diagnostic. I'm sure you're safe to drive on it now, but you should get it checked out
  10. Mar 20, 2017 at 3:56 PM
    flyboy718
    Dallas
    Alright code is checked and here is what it is: P2440 Secondary air injection system switching valve stuck open bank1
    Suggested parts are: Diverter Valve/Air Management Valve
    The guy at AutoZone says that part doesn't even exist for them. Anybody know what to do with this?
  11. Mar 20, 2017 at 3:58 PM
    T4RFTMFW
  12. Mar 20, 2017 at 4:30 PM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    I'm no expert, but I thought that system was brought out in model year 2012. You have a 2005 correct?
  13. Mar 20, 2017 at 4:36 PM
    flyboy718
    Dallas
    Yeap 2005 PreRunner 4 cylinder
  14. Mar 21, 2017 at 6:47 AM
    flyboy718
    Dallas
    Could it just be a vacuum line maybe, how would I check this? I can now hear a whistling sound that wasn't there before when I start the truck after it has been sitting for a while and the automatic choke kicks in.
  15. Mar 21, 2017 at 10:04 AM
    Northern Taco
    Choke? If you have a choke you must have done an engine transplant.
  16. Mar 21, 2017 at 10:08 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Sounds like the engine was from a 2012+
  17. Mar 21, 2017 at 10:10 AM
    Northern Taco
    And I thought that was only on the 4.0L.
  18. Mar 21, 2017 at 10:23 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Guys the 2TR-FE had the air injection since 2005 I believe, 4.0 got it later.
  19. Mar 21, 2017 at 11:50 AM
    Northern Taco
    Ok that I was unsure of. But the choke thing I am sure on
  20. Mar 21, 2017 at 2:45 PM
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
    Yeah the 4.0 got them in 2012
