Check engine light code 0456
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bubba Rhodes, Oct 6, 2023.
  1. Oct 6, 2023 at 6:49 AM
    Bubba Rhodes
    Bubba Rhodes [OP] New Member
    2004 Toyota Tacoma pre-runner
    I replaced the gas cap light is still on guy at the AutoZone SD might have to drive it about 50 to 100 miles will go out eventually.
  2. Oct 6, 2023 at 7:10 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Did you try resetting the code first? If the new gas cap doesn't solve your issue, I'd have an actual EVAP test done before you throw any more money into the parts cannon.
  3. Oct 6, 2023 at 7:11 AM
    Clearwater Bill
    Billy
    Largo Florida
    Disconnect the negative battery cable for a minute then reconnect. Light will be cleared.
    Your AutoZone guy should have offered to plug in their scan tool and clear the code for you
  4. Oct 6, 2023 at 7:16 AM
    RedWings44
    Michigan
    I believe AutoZone usually just uses basic scan tools that can't clear the codes. They've never cleared mine in the past, anyway.
