Check engine light flashing
Discussion in '1st Gen. Tacomas (1995-2004)' started by mcariveau, Dec 15, 2022.
  1. Dec 15, 2022 at 4:49 PM
    mcariveau
    mcariveau [OP] Member
    Michael
    1998 Tacoma
    standard 4 cylinder with 5 speed transmission
    So I fixed the clutch issue now I’ve got another problem. When I left home this evening, truck idled fine and would, rev inneutral but as soon as I get on the road, it starts sputtering and the check engine light starts flashing. I turned around and came back home, parked it and as long as it’s idling in and in neutral, it will run fine but as soon as I put it under a load, it starts sputtering. Not sure if it’s injectors, plugs, fuel pump, etc. Any help would be much appreciated. Thank you in advance.
    Taco critter likes this.
  2. Dec 15, 2022 at 4:52 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Going to need code reader to get fault code to start with
    TnShooter and Taco critter like this.
  3. Dec 15, 2022 at 5:04 PM
    mcariveau
    Michael
    1998 Tacoma
    Thanks guys, what’s the best inexpensive code reader available? I don’t wanna break the bank to fix a $10 part, lol.
  4. Dec 15, 2022 at 5:07 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Don't drive it with flashing CEL
    Misfires can damage engines
    Bishop84 likes this.
  5. Dec 15, 2022 at 7:02 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  6. Dec 16, 2022 at 8:48 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    No need to buy anything.
    Just drive to your friendly OReilly's and then to Autozone and ask if somebody can read out the stored codes. Be ready to write down the numbers as they read them out to you. Then come back here and post them.
    Bivouac likes this.
  7. Dec 16, 2022 at 11:50 AM
    FrankTheTank858
    FrankTheTank858 Well-Known Member
    Frank
    Murrieta, CA
    2006 Tacoma DCSB 4WD
    Flashing CEL means misfires, driving for an extended period of time will damage your catalytic converter.
    once you get the code read and have a cylinder # of the misfire, take the coil from that cylinder and swap it with another cylinder. I also suggest taking the spark plug out of the misfiring cylinder and swapping it with another cylinder (other than the one you swapped the coil with).
    after that, clear codes and see what returns. If code moves with the coil swapped cylinder, replace the coil. If code moves with the spark plug swapped cylinder, replace plugs.
    If the misfire stays, you have bigger problems and will need further diagnosis. Next step IMO would be either swapping injectors or pressurizing the cooling system and sticking a bore scope in the misfiring cylinder.
