check engine light for 2014
Discussion in '4 Cylinder' started by Vagaborn, Nov 19, 2014.
  1. Nov 19, 2014 at 9:26 PM
    Vagaborn
    Vagaborn [OP] Member
    I have a 2014 4cyl with 14,200 miles on it. This morning on start up the engine light came on for a few seconds. Is this a reminder to change oil or something else ?
  2. Nov 19, 2014 at 9:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The Engine light should always come on upon start up. If it stays on, there is an issue.
  3. Nov 19, 2014 at 9:30 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Was it the check engine light or the maintenance required light? If it was the maintenance required, then its an oil change reminder.
    But like he said^^^^^ they should come on for a bit on start up. Th maintenance required will flash a few extra times when you're near oil change, then stay on steady after so many miles.
  4. Nov 19, 2014 at 9:31 PM
    AndyTaco
    AndyTaco ACLBFTMW
    Andy
    Waco, TX
    '10 ACLB V6
    "Raptor Style" grill mod, aftermarket wheels, 265/75/16 Goodyear Wrangler Authorities, TRD Shoulder pads on seat belts, no mud flaps, AVS Hoodflector bug shield *removed*, Dee Zee Ultrablack Bull Bar w/ license plate mount, dipped my fuel door for no reason, N-Fab Spare tire mount w/ full size matching spare, dipped eyelids onto my headlights for no reason, dipped my hood for no reason
    x2.
  5. Nov 19, 2014 at 9:33 PM
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    Just for those of you who don't know, most dealerships set the maintenance light for oil change about every 4,600 miles instead of 5,000. Just in case you think it is coming on earlier than you think it's supposed to.
  6. Nov 19, 2014 at 9:43 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Those lights just come on at startup so you know they are all working. They should all go off after a few seconds.
  7. Nov 20, 2014 at 3:02 AM
    Tacoma Mike
    Southern Maine
    Just to let you know we cannot set the maint light at 4600 miles.
    :annoyed:
    I don't know where all this stuff comes from.
    It's set from the factory and is not changeable.
    It starts to flash for a few seconds about 500 miles before your oil chance time to let you know it's coming due. At the 5000 mile time it will come on solid.
  8. Nov 20, 2014 at 5:45 PM
    Vagaborn
    It is the maintenance required light, I should have specified that.
    So I guess its time to change the oil.
    Thank you
  9. Nov 20, 2014 at 5:56 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    :evil:
    Always a good idea to read the manual.
  10. Nov 20, 2014 at 9:35 PM
    Vagaborn
    I bought the truck used and it didn't have the manual.
  11. Nov 20, 2014 at 9:37 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    If it stays on it's due for maintenance, if it flashes for a few seconds and then shuts off it's giving a heads up you're almost ready for maintenance.
    Welcome to TW!
