check engine light for engine running lean
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HumanityForPresident01, May 29, 2018.
  1. May 29, 2018 at 5:54 PM
    HumanityForPresident01 [OP] Let 'er eat
    Trevor
    2006 Dark Blue Tacoma V6 SR5 EXT Cab TRD Off Road
    2.5" rancho 9000xl lift with UCA's, custom rock sliders, custom rear tube bumper, road armor front bumper, k&n air intake, winch, lights etc.
    Hey everyone
    I had a weekend of off-roading this past weekend and on the drive home me check engine light came on. I noticed it was bogging a bit while passing people on the highway.
    My buddy just came over and used his matco scan tool and it said bank 2 and 1 were running lean. The engine is getting to much air he says. we got some carb cleaner and sprayed all the spots on the intake where things could be loose, and this provided no answers...
    I'm wondering if anyone else has experienced this and if anyone has any suggestions...
    I appreciate all feedback!
    Thanks!!
  2. May 29, 2018 at 6:01 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Smoke it
    scottalot and TexasWhiteIce like this.
  3. May 29, 2018 at 6:02 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    So what code was pulled?
  4. May 29, 2018 at 6:04 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Exactly...... pedal to the metal
    scottalot likes this.
  5. May 29, 2018 at 6:06 PM
    Bebop
    Nick
    I meant smoke test.
  6. May 29, 2018 at 6:09 PM
    Trevor
    smoke what?
  7. May 29, 2018 at 6:09 PM
    Trevor
    how?
  8. May 29, 2018 at 6:10 PM
    Bebop
    Nick
    A smoke test is the use of a smoke machine used to find leaks in many systems.
  9. May 29, 2018 at 6:12 PM
    Trevor
    bank 1 and bank 2 running lean
  10. May 29, 2018 at 6:19 PM
    TexasWhiteIce
    Texas
    Nah man, pedal to metal.... smoke it fast and the furious style!
  11. May 29, 2018 at 6:23 PM
    Trevor
    real funny. i'm worried about my engine
  12. May 30, 2018 at 3:07 PM
    JBCjr
    JBCjr Well-Known Member
    Phila
    06 PreRunnerTRD
    Have you pulled the spark plugs. I felt my truck was running lean. My Spark plugs were bone white except one. After reading a number of posts by @Torspd I believed that it was a clogged fuel filter. Installed the URD fuel pump and external filter kit. The improvement was immediate. Smooth, better acceleration and better gas mileage.
    inwood customs and Torspd like this.
  13. May 30, 2018 at 3:24 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    P0171 and P0174 are the codes for running lean on banks 1 and 2....most times it's related to a vacuum leak so I'd start there. Or a dirty/bad MAF sensor (could be the case since you said it happened after offroading). Check closely for leaks in your vacuum lines and clean your MAF sensor. Other possible causes could be a leak in your exhaust, bad O2 or air/fuel sensors (not sure what 2nd gens are equipped with compared to 1st gens), spark plugs, etc.
    Your air/fuel mixture is lean and throwing the code(s) so you might not be getting enough fuel rather than too much air, so might want to look at the fuel filter as well...though I think that's a much bigger task on 2nd gens being that it's inside the tank. I had this code on my 04 and it took awhile to figure out because there are so many possible causes. For me it ended up being a vacuum leak, mechanic that worked on my truck told me that's what usually trips a lean code.
  14. May 30, 2018 at 3:27 PM
    eon_blue
    Azusa, CA
    You aren't running a K&N oiled air filter are you?
  15. May 30, 2018 at 3:29 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    seafoam baby
    eon_blue likes this.
  16. May 30, 2018 at 3:31 PM
    eon_blue
    Azusa, CA
    could help if the lean issue is related to fuel delivery due to a clogged injector or fuel line, etc. Can't hurt to try it, run a can of Seafoam through the gas tank and another through the throttle body (use the spray can for this). Works wonders on higher mileage motors/systems.
    CarrollTaco2010 likes this.
  17. May 30, 2018 at 3:56 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :hattip:
  18. May 30, 2018 at 5:27 PM
    Trevor
    i will check them, thank you for your suggestion!
  19. May 30, 2018 at 5:29 PM
    Trevor
    i am yes, and for the last three years i've never given me an issue
  20. May 30, 2018 at 5:31 PM
    eon_blue
    Azusa, CA
    I would ditch it and clean or replace your MAF sensor. Those oiled filters gunk them up over time. My last truck had one in it for 2 years before it ruined my MAF sensor and I got this same code (P0171 system too lean, bank 1). Had to replace my MAF and switch to a dry filter and it was fine after that. I know there are many similar reports on this forum as well.
