check engine light for engine running lean
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HumanityForPresident01, May 29, 2018.
  1. May 30, 2018 at 6:25 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Oiled are for MAP based systems. Dry are for MAF based systems.
  2. May 31, 2018 at 9:46 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    but what if you have both :notsure:
  3. May 31, 2018 at 10:15 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    But do you?
  4. May 31, 2018 at 10:42 AM
    coopcooper
    alberta canada
    yeah my evo does
  5. May 31, 2018 at 10:46 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    So you use the filter for the most sensitive sensor. The MAF.
    My Tacoma does as well. :cool:
    lo2hi likes this.
  6. May 31, 2018 at 10:48 AM
    coopcooper
    alberta canada
  7. May 31, 2018 at 11:17 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If you dont want to throw parts at it... you need to look at fuel trims during idle and cruise.
    If you have high fuel trims at idle look for a vacuum leak
    If you have hi trims at cruise or under load look at fuel delivery
  8. Jun 19, 2018 at 11:18 PM
    tgordo49
    tgordo49 Active Member
    Tim
    Boston metro-west
    '15 Black Taco AC TRD Off-Road V6 Tow pkg.
    Spare tire lock, floor mats, UnderCover, P3, V1.
    Now THIS is why I came here today: Looking at my options now that my 2 years free maintenance has ended, and was tempted by the oiled filter option. But now I know better and will avoid needless pain down the road. Thanks, all.
    Now, do I change over to full synth oil or not... Oh who am I kidding, of course I do!
