'Check Engine" light, generic "Gas Cap" code, need help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by enjikari, Jul 5, 2012.
  1. Jul 5, 2012 at 7:35 AM
    enjikari
    enjikari [OP] Active Member
    Michael
    Woolmarket, MS
    05 PreRunner 4.0V6 SR5
    Hello all. '05 here with a 'Check Engine' light. Had it hooked up and coded, gave the generic 'Gas Cap' code (didn't write the code down, sorry). Unscrewed the cap, checked for breaks, put cap back on, had the light reset. Light is back on now. Guy said the code could be the gas cap, the seal, a small leak (somewhere, forget where he said it could be), or the sensor may be bad. Just looking for some general guidance on what I should do next. Is this typical?I'm thinking go buy a new cap and start from there? Dunno if there's some common thing I should check/replace that usually fixes this issue. Mechanical skill is only a 3/10, so I'm kinda in the dark here >.< Any help/advice would be greatly appreciated.
  2. Jul 5, 2012 at 10:22 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I would start with a new cap also. Of course that being said it could be a leak anywhere in the evap system.
  3. Jul 5, 2012 at 2:30 PM
    dhomsey
    dhomsey 03 toyo
    Dennis
    Saint Augustine, florida
    03 preRunner 4 door
    mannik front guard, tail light guards, magnaflow exhust, roof rack. side steps, hood scoop, tint. fishing rod holders, side visor rain guards
    mine always comes on 2003 tacoma. unhook the battery and it goes off, but eventually comes back on. dio test done. shows nothing wrong. my 2000 camry does the same
  4. Jul 5, 2012 at 2:35 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    Could it be from over filling the tank?
  5. Jul 5, 2012 at 4:29 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Over filling the gas tank will dump raw liquid gasoline into the evaporator system and charcoal canister. This will destroy the charcoal canister and will throw an evap system code.
    Short answer: Yes.
  6. Jul 5, 2012 at 4:56 PM
    tacoma steve
    tacoma steve Well-Known Member
    NH
    2012 TX Baja
    I had 2 gas caps both were Toyota caps go on me til I bought one from auto zone that was over a year ago and no check engine light since
  7. Jul 5, 2012 at 5:52 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) You may want to look at your vacuum hoses, as they are 7 years old in a hot engine compartment. There should be a vinyl decal under the hood or near the radiator support that shows a routing of all your vacuum hoses and where they are under the hood. Check them over and feel them to see if they are hard or too soft or if they are cracked. This is most likely after looking at the gas cap. Good Luck.
  8. Jul 5, 2012 at 6:20 PM
    DR Da_da
    DR Da_da Infrequent Member
    Alabama
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    Yikes! When I fill up, I FILL UP! 90% of the time I fill all the way to the port opening. I've had the truck since new, and other than the gas cap seal finally going bad a few months ago I've had zero problems or CEL codes. I guess I should just fill until the pump kicks off!
  9. Jul 5, 2012 at 9:12 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Yeah I knew it throw some code but wasnt sure which one.
  10. Jul 6, 2012 at 4:42 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Pump until it clicks off. at most just round off to even dollars after the first click off. Raw gas will screw up the charcoal canister. They run an average of $300.00 or more.
  11. Jul 6, 2012 at 5:10 AM
    speedjunkie13
    speedjunkie13 Well-Known Member
    a work in progress
    Take your truck to a shop and have them smoke test the EVAP system. this is the easiest way to find a leak. In the long run it would probably be cheaper than throwing parts at it.
    Tacos4ever15 likes this.
  12. Jul 6, 2012 at 9:47 AM
    enjikari
    Michael
    Woolmarket, MS
    Based on my income, I'm gong to start with a simple gas cap swap. Hopefully that will fix the issue. If the problem persists, I'll check the hoses and then have the evap/canister checked. My money is on either the cap or that canister, as I also fill up past the pump's "click". Won't be doing it anymore, that's for sure. :D
  13. Jul 21, 2012 at 12:44 PM
    enjikari
    Michael
    Woolmarket, MS
    UPDATE: Bought a new fuel cap. Few days later, the Check Engine light went away by itself. All is well. Thanks again for the feedback everyone!
  14. Nov 2, 2018 at 6:03 PM
    thetacoman04
    thetacoman04 New Member
    04 tacoma trd
    I have the same problem but I replaced my fuel cap with a cheap one from auto zone and the light is still on. It’s been about 2 weeks. Any suggestions thanks.
  15. Nov 2, 2018 at 6:54 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Get a better cap, like a factory one
  16. Nov 3, 2018 at 2:50 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    Even a new cap can leak. Get a new OEM cap. Clean the cap before you use it, and every time you remove it. Also clean the inlet where the gas cap seats every time. You may think a sealed connection won't collect dirt. WRONG! Every time you get gas you'll be amazed how dirty it got. Plus your new cap will last twice as long.
