Check Engine Light Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bots21, Sep 22, 2011.
  1. Sep 22, 2011 at 8:40 AM
    bots21
    bots21 [OP] New Member
    Colorado
    11 TRD Off-Road Double Cab
    2011 Toyota Tacoma TRD Off-Road Double Cab, AFE Stage 2 CAI, DynoMax Cat Back, URD MAF Cal.
    First off, thanks for all the good advice from all the members here.
    Now to get to it. After purchasing my 2011 Tacoma, I immediately installed a AFE Stage 2 CAI and a Dynomax Cat Cack. I knew these two mods would cause the check engine light to come on, so I wasn't worried. I learned that the URD MAF Calibrator would fix it, so I ordered one and installed it earlier in the week. The check engine light stayed off for a couple days, which would make sense since I disconnected the battery, but it came on again this morning. I plan to check and clean the MAF sensor tonight, but what else should I check? I assumed the MAF calibrator would have helped the light stay off, but.... Maybe the O2 sensor because of the cat back? I know I need to get the codes read, but that'll have to wait until tomorrow or the weekend, but was hoping to check some things out in the mean time. Any advice would be appreciated.
  2. Sep 22, 2011 at 9:20 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    i wouldnt do anything until i knew what codes its throwing. it might be something totaly different from what youre thinking
  3. Sep 22, 2011 at 9:31 AM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    pointless to guess, get the codes pulled and go from there
  4. Sep 22, 2011 at 9:49 AM
    98tacoma27
    Ben
    Not Beech Creek
    X3 And for the record the MAF CAL will not fix any CEL.
  5. Sep 22, 2011 at 9:57 AM
    saugus
    saugus Well-Known Member
  6. Sep 22, 2011 at 5:42 PM
    bots21
    Colorado
    Ok, so I went out and bought a ODBII reader. It is throwing a P0465 code, which according to the little book means "EVAP Emission Purge Flow Sensor Circuit Malfunction." And now I'm lost...please help.
  7. Sep 22, 2011 at 5:49 PM
    bots21
    Colorado
    Thanks. Dealer is three hours away, not that simple. Just trying to figure out if its something simple or not. Could be gas cap..checking that now.
  8. Sep 22, 2011 at 5:57 PM
    bots21
    Colorado
    Sorry, the code it actually P0456, then another code that indicates the P0456p/d, meaning pending. This is my first experience with the OBDII reader. I'll try erasing the codes and see if they come back.
  9. Sep 22, 2011 at 6:15 PM
    saugus
    Pull the gas cap and inspect. Re-tighten firmly. Reset and check.
  10. Sep 23, 2011 at 4:42 AM
    98tacoma27
    Ben
    Not Beech Creek
    X3 on the gas cap. To you turn it till it clicked three times?
