Check engine light is still on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tshadow6, Aug 13, 2017.
  1. Aug 13, 2017 at 2:45 PM
    tshadow6
    tshadow6 [OP] Member
    Tampa Bay, FL
    05 PreRunner
    My check engine light came on at 90k miles. The diagnostic tool read the variable speed sensor was bad. I changed the one by the transmission, but the light is still on. Where else do I look for a speed sensor?
  2. Aug 13, 2017 at 2:46 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Did you clear the light after you changed it?
  3. Aug 13, 2017 at 3:26 PM
    tshadow6
    Tampa Bay, FL
    05 PreRunner
    Yes. I brought it to my mechanic for an oil change and he checked it also.
  4. Aug 13, 2017 at 3:32 PM
    Bebop
    Nick
    If the light came back on with the same code maybe it's time to get an actual diagnostic done. The code would help.
  5. Aug 13, 2017 at 4:00 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Electrical tape should fix it
    koditten likes this.
  6. Aug 13, 2017 at 4:07 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Isn't that a wheel speed sensor issue? There are 4. Have any work done or any trauma to a specific wheel?
  7. Aug 13, 2017 at 4:08 PM
    koditten
    Kirk
    Central Michigan
    I like but not actual help.
