Check Engine Light , Jump or Paperclip? No Reader..
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sixgun, May 25, 2012.
  1. May 25, 2012 at 10:12 AM
    Sixgun
    Sixgun [OP] Well-Known Member
    Mobile, Alabama
    2024 DCSB TRD OR
    Can I use a Paperclip or something along those lines to read a CEL? I don't have a reader and won't be able to get up to the parts store for another couple days. Remember in the past on other vehicles I could just jump it and count the flashes. Been searching but no luck..
    Thanks, Sixes
  2. May 25, 2012 at 11:11 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Not on an OBD-II
    That trick only worked with the original OBD-I connector and you would read a 2-digit code from the CEL.
    OBD-II is a 4-digit code and there's a LOT more of them.
  3. May 25, 2012 at 11:13 AM
    98tacoma27
    Ben
    Not Beech Creek
    If the truck is drive-able, stop by a local parts store. Many of them will read the code for free.
  4. May 25, 2012 at 11:33 AM
    98tacoma27
    Ben
    Not Beech Creek
    No, not OBDII codes. It has it's own codes for the radio failures.
  5. May 25, 2012 at 11:50 AM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Yeah I went to O'reilly's which I believe used to be Schucks up here and they let you take a scan tool out for free as long as you leave your ID. I had to clear some codes created from installing a CAI
  6. May 25, 2012 at 12:01 PM
    jeepdude
    jeepdude Regular Member
    Jesse
    Connecticut
    2004 ext cab 4x4 TRD, bone stock for now
    -Yep, my bad
  7. May 26, 2012 at 9:30 AM
    Sixgun
    Mobile, Alabama
    2024 DCSB TRD OR
    Thanks fella's. Oddly enough someone was holding a garage sale outside my place of business and had an ob2 scanner for sale. Talked them into letting me use it for 5mins.
    Pulled code p0402. Guessing I'll need to be looking into my EGR.
  8. May 26, 2012 at 9:49 AM
    98tacoma27
    Ben
    Not Beech Creek
