Check engine light just came on
Discussion in '1st Gen. Tacomas (1995-2004)' started by sirsaechao, Feb 17, 2012.
  1. Feb 17, 2012 at 8:36 PM
    sirsaechao
    sirsaechao [OP] Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Its 9pm and my light just came on...any idea where to start to find a code? It started the stall when I hit the gas pedal.
  2. Feb 17, 2012 at 8:40 PM
    sirsaechao
    Tim
    Commifornia
    Where is the hookup port at?
  3. Feb 17, 2012 at 8:41 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Check for loose hose clamps and/or cracked or disconnected vacuum hoses. Check around EGR for burnt or pinched wiring.
  4. Feb 17, 2012 at 8:42 PM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    right under dash above your gas pedel. it is black with alot of little holes in it should be kind of rectangular
  5. Feb 17, 2012 at 8:44 PM
    sir1123
    Charleston
    you need to just get it scaned but when mine started to stall when i got it at 160k it was my MAF. change your PCV valve also, its cheap probably need new one anyway if not the problem
  6. Feb 17, 2012 at 9:07 PM
    01TacoBuz
    01TacoBuz Well-Known Member
    In the woods
    01 Tacoma SR5
    K&N drop in filter, URD rear simulator, Deck plate mod/home made CAI, No rear cat, MagnaFlow muffler
    Just below your hand brake
  7. Feb 17, 2012 at 9:29 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    mine poped on yesterday, funny i was planning on working on it this weekend. took it to autozone, and its the ol Idle air valve, needs cleaning.
  8. Feb 18, 2012 at 12:36 AM
    sirsaechao
    Tim
    Commifornia
    I'll have to hook up my bro in laws reader and see what code I get and post it for some help.
  9. Feb 19, 2012 at 8:26 AM
    sirsaechao
    Tim
    Commifornia
    Update so I got a OBDII reader hooked it up and 0 codes came up and the check engine light is gone w/o me even doing anything like hitting the erase button???
  10. Feb 19, 2012 at 8:36 AM
    01TacoBuz
    In the woods
    01 Tacoma SR5
    Wait and see if the light comes back on so you can get a readout on which codes it`s gonna throw
    No need to start changing parts when you`re not sure if they are bad
