Check Engine Light - No Cruise - After moderate pot hole
Discussion in '4 Cylinder' started by EvilBetty, Dec 8, 2012.
  1. Dec 8, 2012 at 11:11 PM
    EvilBetty
    EvilBetty [OP] Well-Known Member
    Kansas City, MO
    07 SR5 Access Cab
    Visor CD Holder
    Have about 97k on the truck now.
    Drove an hour to a friends house, drove through a clear field. Drove an hour back home. Hit a pop hole on with the front left wheel pulling out of a fast food place and I hear a small click and the check engine light came on. I got n the highway on the last leg home and the cruise would come on but not engage. No other symptoms. I'm heading to Autozone tomorrow to check for codes.
    The only thing after market I have on the truck is a navigation deck with splice on the speed wire and rear brake light for the backup camera.
  2. Dec 11, 2012 at 5:56 PM
    SitkaSpruceMica
    SitkaSpruceMica Well-Known Member
    TC
    SE Alaska
    2013 SR5 4x4 I4 Auto AccessCab
    Check your wheel speed sensors. If they are not reading correctly the cruise will be disabled. The ABS may not work correctly either if this is the case so get it checked soon.
    TC
  3. Dec 11, 2012 at 5:59 PM
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    I don't know if this is an issue with Tacomas, but my old Colorado had a problem with the brake light sensors going bad which would cause the cruise control to not work.
    Do your brake lights light up?
    Just throwing out ideas, good luck.
  4. Dec 11, 2012 at 5:59 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    im betting you probably need a new wheel bearing. i slid into a curb with my reg cab and broke my wheel bearing in a snow storm, didnt have cruise, but im sure thats your problem. if you have a warranty, they will cover it. at least they did for mine....
  5. Dec 11, 2012 at 8:49 PM
    EvilBetty
    Kansas City, MO
    07 SR5 Access Cab
    Visor CD Holder
    Yeah code is reading P0500 Speed Sensor A
    Today I had the brakes checked and drums cleaned and adjusted at Firestone. I don't know if they knew what to look for, I don't. :confused:
    I tried clearing the code but it's being thrown constantly as I go down the road.
  6. Dec 11, 2012 at 8:59 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Check for the wires at each wheel to make sure that they are tight.
