Check engine light o2 sensor 05 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iiiquaziii, Jul 19, 2019.
  1. Jul 19, 2019 at 11:35 PM
    iiiquaziii
    iiiquaziii [OP] Member
    06 Silver Tacoma 2wd
    None
    Hi all. So I got my truck inspected the other day in NYS. Wouldn't ya know it, an hour after I got my sticker, the check engine light came on. It never has before. Glad it happened AFTER, or I would have failed. I've got a 2005 Tacoma, 4 cyl. I pulled the codes with a cheap scanner, and cleared them, but the light came back on, so something is up. The code I got is a P0137. Oxygen sensor, Bank 1 sensor 2, low voltage it says. After some research, and youtube watching, it seems to be the heated o2 sensor right after the catalytic converter. I ordered a new one from the parts store. Autozone, Advance Auto, and Rock auto all had several selections for the sensor. I ordered the Denso 234-4261. I ordered it because it said the Denso one was the OEM sensor on Autozone's website, vs the other choices that just said "exact fit aftermarket part". Can anyone verify this is correct? I don't really trust Autozone as a source of factory parts information. I really need to get a factory service manual.
    The sensor should be here soon. I have had REALLY bad luck replacing o2 sensors in the past on other vehicles. It seems like I always need to order 2, just to get 1 good one. Anyone else have this problem? Same with parts store TPS sensors. Hopefully this isn't the case this time.
    Can anything else cause this code? Other than an exhaust leak, or maybe a bad catalytic converter?
    Anyone have experiences to share?
    Thanks,
  2. Jul 20, 2019 at 12:38 AM
    eon_blue
    Azusa, CA
    I had the equivalent code for my rear 02 sensor on my 04 and replacing the sensor solved it
  3. Jul 20, 2019 at 4:34 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Always stick with Denso or NTK for 02 sensors.
    R0dzilla75 likes this.
  4. Jul 27, 2019 at 5:21 PM
    iiiquaziii
    None
    Soooo......I put the new sensor in today, and checked for exhaust leaks up front. No leaks. Cleared codes, took it for a drive, and engine light is back on..... Same code. Any ideas?
  5. Jul 27, 2019 at 7:39 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Service Manual: http://www.customtacos.com/tech.old/files/05FSM/repair.html
    For the 4 cylinder P0137 Code: https://www.customtacos.com/tech.ol...06toyrm/06toypdf/06rmsrc/rm2006ta/0060026.pdf
    Triggers:
    • Low voltage (open):
    During active air-fuel ratio control, following conditions (a) and (b) met for certain period of time (1 trip detection logic):
    (a) HO2 sensor voltage output less than 0.21 V
    (b) Target air-fuel ratio rich
    • High impedance:
    Sensor impedance 15 kΩ or more for more than 90 seconds when ECM presumes sensor to being warmed up and operating normally (1 trip detection logic)
    Causes:
    •Open in HO2 sensor (sensor 2) circuit
    • HO2 sensor (sensor 2)
    •HO2 sensor (sensor 2) heater
    •EFI relay
    •Gas leakage from exhaust system
    iiiquaziii[OP] likes this.
  6. Jul 27, 2019 at 7:55 PM
    iiiquaziii
    None
    Thanks! The manual is always helpful. I'm leaning toward an open in the circuit....perhaps a bad wire in the harness. I'll have to do some more poking around. The frame was recently replaced, so a wire could conceivably have gotten stretched/kinked/pinched.....
    whoareyou133 and Jimmyh[QUOTED] like this.
  7. Jul 27, 2019 at 8:27 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I agree. Go through the wire harness.
    whoareyou133 likes this.
