Check engine light off after check codes
Discussion in 'Technical Chat' started by CUtacomaTIGER, Feb 2, 2012.
  1. Feb 2, 2012 at 7:17 PM
    CUtacomaTIGER
    CUtacomaTIGER [OP] Unprofessional Driver
    San Diego
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges Window Rain Guards Bed Liner
    my truck spit out a check engine light so i went to go have it read.
    after reading code, i started my truck again and the light doesn't come on any more.
    i think the code got erased but the tech at the auto parts store said he wasn't going to clear it, so if he did it was an accident. although i not sure if computer will let you clear it unless you disconnect battery for a while or fix the problem.
    i figure if it wasn't just a random mishap (since truck runs fine) it will come back on. is that a safe assumption or not?
    code was (P0115) engine coolant temperature sensor if that matters any.
  2. Feb 3, 2012 at 8:12 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    The guy probable cleared the code. If the coolant temp sensor is bad the check engine light will reappear.
  3. Feb 3, 2012 at 9:10 AM
    CUtacomaTIGER
    San Diego
    what i was thinking as well.
  4. Feb 3, 2012 at 4:07 PM
    Tacoma Mike
    Southern Maine
    Yes it can happen. Check for a code, read it, and just disconnect and it clears. Have no idea why... Could be a glitch in the software of the scan tool.
    My hand held has done it a couple on times in the past few years. If it happens again and it's the same code then get it looked at.....
