Check engine light on well maintained truck
Discussion in '1st Gen. Tacomas (1995-2004)' started by GreatWhiteTacoma, Jul 23, 2025.
  1. Jul 23, 2025 at 9:26 PM
    GreatWhiteTacoma
    GreatWhiteTacoma [OP] Active Member
    2000 silver tacoma 2.4l 5 lug
    2000 4-cylinder, extended cab Tacoma
    The light came on this morning and it gave me the motivation to get some work done that I've been planning to do for a while. In the process I cleaned out the MAF sensor and checked for vacuum leaks. Replaced all the gaskets from the head up (not the head gasket itself). Replaced spark plug wires and plugs, new belts were due too. Cleaned out a bit of sludge but the light stays on. Engine runs smooth and no decrease in mileage. Gas cap is on tight. Is the only way to really determine what's going on by getting a code reader? I tried everything I could find info on but light stays on.
    As for the sludge, I change my oil every spring and every fall, only drive about 6000km a year but in a cold climate. That means lots of idling. The sludge was localized around the back of the engine, where the PCV valve is. I scraped most of it out but obviously couldn't get 100% of it. My plan is to now change my oil every 2000km or 3 months whichever is first with a high detergent oil. Or I could do an engine wash additive thing but I'm weary of that due to clogging oil line possibilities. Open to suggestions on this matter
  2. Jul 23, 2025 at 9:33 PM
    truckmike26
    truckmike26 New Member (2009)
    Toronto
    '21 DC TRD Off-Road, '94 Pickup (Hilux) V6/Auto 4WD
    Get a code reader. Canadian Tire puts them on sale quite often.
    Jakerou, wilcam47 and Kwikvette like this.
  3. Jul 23, 2025 at 9:36 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
  4. Jul 24, 2025 at 7:35 AM
    Glamisman
    Glamisman Well-Known Member
    Many auto parts store will do a free code scan in hopes of selling you a part. Dont fall for it. If you do go this route get the code and ask for the freeze frame data. When code(s) are set the PCM stores the data that triggered the code, this is usually more informative than the code. Use your phone and take a picture of the screen(s) and upload them here and advice will be given.
    t0p_d0g likes this.
  5. Jul 24, 2025 at 9:12 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Where was this sludge you are concerned about? In the intake manifold? That's not really sludge that increasing oil change frequency will help improve. Build up in the intake manifold is due to the PCV line, and if equipped EGR.
    SpencerTacoSC likes this.
  6. Jul 24, 2025 at 10:36 AM
    Red_03Taco
    Jerad
    I interpreted what OP said to mean the sludge was under the valve covers just inside of where the PCV hose exits, but perhaps thats not what he meant
  7. Jul 24, 2025 at 10:49 AM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Well maintained, while admirable, doesn't mean that things won't still happen. As said above, get the codes read.
    Evostaco likes this.
  8. Jul 24, 2025 at 7:46 PM
    GreatWhiteTacoma
    You are correct.
  9. Jul 24, 2025 at 8:46 PM
    Red_03Taco
    Jerad
    Well in that case high quality synthetic oil with good detergents, changed every 5k miles or 6 months (whichever comes first) is about all you can safely do
  10. Jul 24, 2025 at 10:05 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    CODES!!!!!!
    t0p_d0g likes this.
  11. Jul 25, 2025 at 12:56 PM
    SpencerTacoSC
    SpencerTacoSC Well-Known Member
    Daniel
    2004 Tacoma 4x4 V6
    Yep. No matter how well-cared for, engines are mechanical devices that will wear out over time.
  12. Jul 25, 2025 at 3:37 PM
    GreatWhiteTacoma
    Yeah I am aware, I wasn't saying so much as it is so well maintained that how could anything possibly go wrong, it was more a question of what is a common issue that could occur to an otherwise well maintained truck.
    Will get the codes read
  13. Jul 25, 2025 at 4:00 PM
    ChinoXL
    ChinoXL Well-Known Member
    95 Tacoma V6 MT 4x4 Xtracab
    What is the general consensus on engine flushing products such as liquimoly/seafoam etc?
  14. Jul 25, 2025 at 5:22 PM
    SpencerTacoSC
    Daniel
    2004 Tacoma 4x4 V6
    Are you trying to solve a specific problem? If no, don't bother. Unlikely to hurt (properly used), but also you're going to be spending money for no return.
    ChinoXL[QUOTED] likes this.
  15. Jul 25, 2025 at 5:27 PM
    eon_blue
    Azusa, CA
    These old trucks will toss codes every now and then it’s just the nature of driving an older vehicle no matter how well maintained. Without the code though we are just shooting in the dark. Generic code readers are cheap and an extremely valuable tool to have on hand with an older vehicle, rather than having to rely on a parts store or shop to do it every time one pops up
  16. Jul 25, 2025 at 5:45 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Yes, rubber, plastic, and electrical parts all could fail around the engine with 25 years of rot and heat cycling. Could be any one of 50 reasons you have a CEL. Get a scan tool, read codes, and look at live data. Blindly shooting the parts cannon any further will do more harm than good.
  17. Jul 25, 2025 at 7:20 PM
    Red_03Taco
    Jerad
    I think if there's enough of something built up in your engine to want to flush it out, then your likely to cause issues by using a strong flushing product. Hence why I suggested just relatively frequent oil changes with high quality oil. Anything more aggressive than that seems too risky in my opinion
  18. Jul 25, 2025 at 7:36 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    How hard is it to get the codes read?
    ChinoXL and ControlCar like this.
