Check Engine light on WTF
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sardog2111, Jun 17, 2009.
  1. Jun 17, 2009 at 9:11 AM
    sardog2111
    sardog2111 [OP] Well-Known Member
    AL
    05 silver streak DC, 5100, borla exhuast
    5100's, Volant Intake, Borla Exhaust. FJ wheels, Wet Okole's. HID's, Go Rhino Steps bars.
    So woke up this morning started the truck and it stalled out. Turned the key again and it started the check engine light stayed on and I thought I will take in to the shop after work. Well got to the end of the street and it died again. Started it back up and drove out the sub division. As I was going down the road it sputtered had no power and would not go above 2000 RPM's Has anybody ever seen this before? Keep in mind my truck is an 05 DBL Ccab with 99,500 miles on it. Very welll maintained. I am thinking one of the sensors just crapped the bed. Tow truck took it to the dealership just wanted to see if anybody has experienced this before?
  2. Jun 17, 2009 at 9:16 AM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    I'm taking a real wild guess here, but it almost sounds like that the MAS airflow intake sensor is either faulty or the the connection to it is bad. It could also be a loose vaccum hose. Any of those that come loose can screw stuff up. The only reason I say this is that on several occasions I've forgotten to reconnect the airflow sensor on mine and the truck will do exactly as you described.
  3. Jun 17, 2009 at 9:22 AM
    sardog2111
    AL
    I was thinking that exact same thing. I really hope that you are I are wrong because I here that sensor is super pricey. I was hoping for something like an 02 sensor or something along those lines. A vaccuum line would be really nice, but not sure that I am that lucky.
  4. Jun 17, 2009 at 9:34 AM
    bobwilson1977
    KaliFORN-I-A
    If its the MAS sensor, tell them you'll replace it yourself. Its a 5 minute job. That'll save you quiet a bit of money on labor.
  5. Jun 17, 2009 at 9:42 AM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    Go to autozone or kragen or somethin on those lines.. they will hook your car up to a code reader for free and find out what sensor is throwing codes and what those codes are.. Then you can do a bit of research and figure out the problem yourself without Toyota charging you an arm and a leg..
    my .02
  6. Jun 17, 2009 at 9:49 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    I am thinking it is the throttle by wire.
    :popcorn:
  7. Jun 17, 2009 at 10:37 AM
    sardog2111
    AL
    well it is at the dealership right now 70.00 just to get it there and we will see what the issue is. Not much I can do right now but wait until they tell me what the issue is hopefully it is not to much. Yeah right did i just say that..........
  8. Jun 17, 2009 at 10:53 AM
    jefferson
    Sex Panther
    05 PreRunner SR5
    aaahhh for $70 you could buy a code reader and do it in your driveway :(
  9. Jun 17, 2009 at 10:59 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2009 DC V6 TRDsport
    5100's all around - fronts at 1.75", 265/70/17 Bridgestone Revo 2, HID headlights and fog lights, factory skid plate, ss exhaust tip, tube steps, Access roll-up tonneau cover, Redline hood struts, 6 D-rings, seat MagLite, LED dome, fumoto oil drain, DTRL, fog light anytime, Kenwood/Clarion speakers, Pop-N-Lock 5300, LED bed lights and a few other things...
    Interesting that you stalled out twice and continued to travel down the road. I would've turned it around and got it back to my house. It was obvious something was wrong.
    Sorry I can't help but i'm waiting around to hear what the problem is.
  10. Jun 17, 2009 at 11:13 AM
    sardog2111
    AL
    I did get it back to my house. It was in my driveway did not think about the code reader from the auto store. IT was early and I needed to get to work my only option was call tow truck and get it fixed and find a way to pick up my son from daycare. Yeah what PIA morning it has been. Just one of those days. :eek:
  11. Jun 17, 2009 at 12:30 PM
    jokerjp
    jokerjp Active Member
    central IL
    TRD off road rugged trail
    Fuel pump?
  12. Jun 17, 2009 at 4:36 PM
    sardog2111
    AL
    alright the long awaited 180.00 dollar answer was an O-ring on my volant (MAS) intake cracked melted a 10 amp fuse that ran the fuel injection system. This is a bummer that no scanner would have picked up. Well at least it runs now and I know if that O-ring goes bad again what it will act like. Expensive O-ring hey.....
  13. Jun 17, 2009 at 5:01 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    That sucks. At least it was minor. Nice to have only little problems like that huh
  14. Jun 17, 2009 at 6:15 PM
    sardog2111
    AL
    yeah it could have been way worse. Did not know o-rings had such a markup and fuses wow those are hard to come by now days. No really it was a little steep but it could have been worse and I had a buddy stick his neck out for me to so it all worked out in the end.
  15. Jun 17, 2009 at 7:02 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Good to hear you're back on the road at least.
  16. Jun 17, 2009 at 7:30 PM
    sardog2111
    AL
    yeah exactly. I just wanted to let everyone know that if you have a volant intake or maybe even a TRD intake that if that O-ring for the MAS goes out it really going to make your truck do some really odd things. Order another O-ring or find one that wiill work to keep on stand-by. Also watch you 10 amp micro fuse for you fuel injection system. The combination can be costly. I may have got off easy compared to a dealership that will say that the aftermarket intake and the O-ring caused your MAS to fail and charge you 300 or 400 when all you really need is a 2.00 o-ring.
  17. Jun 17, 2009 at 7:59 PM
    sardog2111
    AL
    wow give you props and you bitch slap me. ha ha Will call you at 5 when I get up. Or better yet keep the secret service around your truck you never know what I may need......... Thanks again buddy.
  18. Jun 17, 2009 at 8:55 PM
    TacoTurd
    TacoTurd Defying Alliances since 2007
    Central Texas
    07 PreRunner TRD Sport
    TRD Exhaust, TRD CAI, Bull Bar, PIAA lights, Passport, Bed Mat, UWS Toolbox, Hood Struts, Rear TSB, TRD/Okole Seat Covers, Hellwig Rear Sway Bar, Burned Carpet, Nasty Dent in Roof
    Havin a tuff time here connecting an o-ring to a blown fuse :confused:
  19. Jun 18, 2009 at 9:14 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    X2
    I want to know what the code was.
  20. Jun 18, 2009 at 9:44 AM
    sardog2111
    AL
    not sure myself how they go together. Best guess is that when the O-ring cracked it disrupted the MAS and blew a fuse. I was told that it did not give a specific code.. It was a general code for a short somewhere in the electrical system. This took the teck on a search and they found a blown fuse in my fuse box. all of it is really weird and the oddest part is the fuse that was in there was not even a micro fuse it was a mini. It did not hae any business even being in there. Nobody has worked on my truck except for the tire shop and they only did the tires nothing else. So I am not even sure how the fuse got in there to begin with.
