Check Engine Light-P0128 Thermostat
Discussion in 'New Members' started by NHRodster, Feb 22, 2023.
  1. Feb 22, 2023 at 3:49 AM
    NHRodster
    NHRodster [OP] New Member
    Jared
    2017 Tacoma TRD Off-Road
    None
    I just had my check engine light come on my 2017 Tacoma. Reader showed a code for P0128 stating the thermostat is potentially stuck open. When driving my engine temp needle doesn't really move showing it's heated up but vehicle runs fine. Everything I researched showed that I needed to replace the thermostat, questions is if anyone has had experience with this and if its better to replace just the thermostat or the whole unit. Also, done normal vehicle maintenance like oil changes, spark plugs, engine coils so not sure if this project is too much for me to handle. Looking for advise on the code mostly and if anyone has had experience!
    buckhuntin-tacoma likes this.
  2. Feb 22, 2023 at 5:34 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  3. Feb 22, 2023 at 5:45 AM
    Bishop84
    Bishop84 Well-Known Member
    It’s a complete unit, very common.
    NHRodster[OP] likes this.
  4. Feb 22, 2023 at 8:15 AM
    70guitarman
    70guitarman Member
    Eltee
    Tucson
    2005 Tacoma sr5 trd double cab
    3inch lift duel flowmaster set up
    ECT sensor check! Before replacement of thermostat.
  5. Feb 22, 2023 at 4:07 PM
    NHRodster
    Jared
    None
    Thank you both very much! I'll look into how to do an ECT sensor check first and then will probably just do a whole unit swap if that's all good!
