Check engine Light P0500 speed sensor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BloodNightmare24, Jan 21, 2015.
  1. Jan 21, 2015 at 2:10 PM
    BloodNightmare24
    BloodNightmare24 [OP] New Member
    Colorado
    07 Base 4x4 2.7l
    Volant Ram Air, Two chamber muffler, 3inch kit on 265's
    Hello all!
    My truck is a 2007 2.7L 4x4 standard with about 100,750 miles.
    recently my check engine light came on and the code is P0500 indicating the speed sensor is faulty. However my speedometer is still working properly.
    My truck idles at very low Rpm and causes the truck to shake while stopped at traffic lights and it seems like my the the truck has lost some power in my mid range.
    I initially changed all my plugs and added seafoam expecting I might have picked up some bad gas. It smoothed out at first but now I'm back to the same P0500 and a rough low idle (probably 500rpm while stopped).
    Any idea what my problem is? should I replace the speed sensor even tho my speedometer is working? What other steps can I take to get it back to normal?
    Thank you for any help!
  2. Dec 28, 2020 at 11:06 AM
    avery0829
    avery0829 Well-Known Member
    Western Washington
    2005 Tacoma DCLB Sport
    Bilstein 5100, Trail edition wheels, 265/70/17 Falkens
    Did you figure your issue out?
