check engine light que..
Discussion in 'Technical Chat' started by MagnecticgraySR5, Nov 30, 2013.
  1. Nov 30, 2013 at 3:20 PM
    MagnecticgraySR5
    MagnecticgraySR5 [OP] Well-Known Member
    florida
    2010 prerunner
    hay tacoma family, my check engine light came on along with the traction control light. Does anybody have any idea what that means or has it happen to anybody:confused: Any information would help, thanks........
  2. Dec 2, 2013 at 7:22 PM
    DaBears
    DaBears Well-Known Member
    CONUS
    10 trd sport
    Mine did to today I have 59,000 miles on the clock.
    What did you end up doing?
  3. Dec 5, 2013 at 9:13 AM
    MagnecticgraySR5
    florida
    2010 prerunner
    i had my friend clear the code. it said something about the exhaust.. so my friend said just remember to tighten the gas cap
  4. Dec 8, 2013 at 3:46 PM
    BamaToy1997
    Bill
    Navarre, FL
    It is not uncommon for a traction failure to result in a CEL, or a CEL code resulting in a trac off condition. They both work hand in hand. If it comes back I would suggest reading the code and getting it diagnosed.
  5. Dec 8, 2013 at 6:43 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Top of my head every vehicle I've owned with traction control turns on both lights at the same time, at least every time it's happened to me.
    You didn't mention the code but by the gas cap comment I'm guessing it was P0456 (evap leak). Like BamaToy said, see what it does the next few days..
  6. Dec 12, 2013 at 6:54 PM
    DaBears
    CONUS
    10 trd sport
    Thanks guys, you were a huge help. My wife took it to the dealer on the 5th. I should of waited, $44 later she was told to tighten the gas cap. that will be the first thing I look at from now on.
  7. Dec 12, 2013 at 7:02 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    BE WARNED!!! I had the same issue that occurred around March 2013. I had it checked at OReillys and it was P0456 (small evap leak): no big deal. I took it to the shop a day or 2 later to have them see where the leak was...they couldnt find it and sold me a new gas cap (88$) and said itll fix it. I drove and the next day, BAM! same light, 88$ wasted. I took it back, they couldnt figure it out. Now its OCT2013, tell them hey, its still on, i dont notice any driving difference performance wise, but I would like to know whats wrong. They smoke test it, dont find any leaks, check the ECU, REFLASH THE ECU! to clear the system, says it should take care of it. ON THE WAY HOME it comes back on, like a slap in the face. I take it back, they tell me the charcoal canister needs replaced, I say ok. 130$ later they say its fixed. Works for 2 days, and the light is back on and continues to be on to this day. I called back and they contacted Toyota and told them the problem, they have no solution yet but said its being looked into. Keep diving into it so they see its more people with the problem so they take it more seriously and find a solution. Im waiting for a TSB to come out. Hope this helps you, and everyone else with this problem.
  8. Dec 14, 2013 at 9:21 AM
    MagnecticgraySR5
    florida
    2010 prerunner
    thanks guys, next time i will get the code.....
    i feel you and i would be pissed after all that money i would have spent.
