check engine light quick fix
Discussion in '1st Gen. Tacomas (1995-2004)' started by mudjunkie, Aug 11, 2008.
  1. Aug 11, 2008 at 7:51 PM
    mudjunkie
    mudjunkie [OP] Well-Known Member
    clearwater fl
    96 tacoma sx l
    header,short rack and pinion, heavy duty shocks, grill guard, flowmaster exhaust,pacesetter header without catalytic converter, one 10 inch xant sub with a mtx amp, off road lights,diamondplate tool box,rhinolined inside cab,ngk plugwires.
    turns out if you have a check engine light on and you know the problem once you fix it disconnect the battery and wait ten minutes the reconnect the battery as long as you fixed the code your check engine light does not turn back on.
  2. Aug 11, 2008 at 7:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Posted in the wrong post.
