check engine light reset
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jimboo, Aug 3, 2009.
  1. Aug 3, 2009 at 1:55 PM
    jimboo
    jimboo [OP] New Member
    Courtice, on, canada
    09 access, 2.7, std, 4x4
    my wife is learning to drive my 09 tacoma std shift truck. after repeated enginge stalls while practising uphill take offs, the check engine light comes on. how do i reset it?
    jimboo
  2. Aug 3, 2009 at 1:55 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    unhook ur battery for bout 15 mins or longer
  3. Aug 3, 2009 at 2:14 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Depends on why- Go to an Autozone or PepBoys and have the code read- If it's something that makes sense from a lot of stalls then they might clear it....they might not.
    Better to err on the side of caution IMO- Check it insted of just trying to force clear it...Could be an actual problem...
  4. Aug 3, 2009 at 2:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2. The CEL should clear itself if the engine is stalled. If it stays on after that, something may be amiss.
  5. Aug 3, 2009 at 3:39 PM
    otter
    otter Well-Known Member
    Rob
    MI
    09 4 cyl Reg Cab
    Buy yourself a simple $30 code reader. They're handy to have and should be a staple tool in any garage.
  6. Aug 3, 2009 at 6:19 PM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    Since it's new, take it to the dealer and let them deal with it.
