check engine light, rough idle...
Discussion in 'Technical Chat' started by Boulderjoe, Sep 7, 2014.
  1. Sep 7, 2014 at 7:14 AM
    Boulderjoe
    Boulderjoe [OP] Member
    Joe
    Boulder
    05 CrewCab Longbed
    It's early on a Sunday morning and I'm trying to figure out my engine problem.
    Here's what happened.. (2005 4L)
    We had a really hot day (100°F)
    I was really low on gas.
    My gas cap was defective (loose) but everything ran fine.
    The next day I noticed that my "check engine" light was on and my engine ran really rough when moving. I filled the tank and bought a new gas cap. I've started the engine a few time but it's really rough... any ideas?
  2. Sep 7, 2014 at 7:41 AM
    Tacoma Mike
    Southern Maine
    Truck needs to see 3 good " global trips "
    Meaning cold start and run at temp for certain time and speed then a complete cool down and start again.
    Some codes never clear and remain with a cel until scanned and manually erased.
    Since you now have a drivability issue I suggest getting the system scanned.
    If your tank was real low you could have sucked up some crap.
    Start with a scan before you throw things at it you may not need.
  3. Sep 7, 2014 at 8:28 AM
    Boulderjoe
    Joe
    Boulder
    05 CrewCab Longbed
    I got a scan; it had 4 "loose gas cap" and a "cylinder 3 misfire." Gas cap is fixed now I need to investigate the misfire. Hmmm.
  4. Sep 7, 2014 at 2:39 PM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    try swapping coils
  5. Sep 7, 2014 at 2:48 PM
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    2017 TRD Off Road
    12voltsolutions.com plug-n-play remote start system. OVTuned OEM Bed lights Underhood and footwell lights Garmin dash-cam Weathertech side vents, bug shield, mud flaps and floor mats Extang Encore tonnau cover OME BP51 Suspension Front & Back / Dakar Leaf Springs Light Racing UCA's XD Holeshot 17" x 9" Wheels Nitto Trail Grapplers 265/70/R17 TRD Pro Grille Raptor Lights iJDMToy 30" LED Hidden Bar Light Toyota Bed Step
    Bad injector? Bad spark plug? Junk in the system from the tank being so low?...
  6. Sep 9, 2014 at 3:39 PM
    Boulderjoe
    Joe
    Boulder
    05 CrewCab Longbed
    It was a spark plug. However, I paid the local shop to tell me that. $160. Sucks to pay that much but it' a lot less than I was worrying about! I guess I just learned to change the spark plugs every 100k miles or so, eh?
  7. Sep 9, 2014 at 3:43 PM
    BJsFJ
    BJsFJ Well-Known Member
    Bailey
    Encinitas CA
    '11 Single cab 4x4
    From personal experience.. on another toyota vehicle.
    Do it at 30k, 60k, 90k, 120k, 150k..
    At those intervals I also change Rear Diff, Transfer Case, Front Diff, coolant
    Transmission every 60k miles. That's just my choice. Could be too much too soon, but it gives me peace of mind and I am a DIY type of guy
