Check Engine Light Ruined My Trip
Discussion in '1st Gen. Tacomas (1995-2004)' started by theGastone, Mar 21, 2012.
  1. Mar 21, 2012 at 5:32 AM
    theGastone
    theGastone [OP] New vehicle/Tacoma *****
    Ian
    Leesburg, VA
    '97 Standard
    So I've been planning for a few weeks to go fishing down at Sebastian's Inlet here in sunny Florida, and this morning when me and my buddy were headed to Walmart to fill up our cooler, my check engine light came on. And since I was wearing sandals I noticed that there was a lot of hot air blowing on my feet. I thought this was a bit peculiar seeing as I hardly use my A/C, I usually just have the windows down. I did have the windows down and I could still feel the excessive heat on my feet. I checked all the fluids just in case and all of them were just fine. So since I'm not going to drive 2 hours there and 2 hours back with my check engine light, on I'm super pissed that I had to cancel this trip. I'm going to go later today to get a diagnostic, and I'll update this thread with the result. In the meantime I was wondering if y'all had any ideas as to what this issue could be.
  2. Mar 21, 2012 at 5:44 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    We could only speculate. There are numerous codes that can pop up and the truck will run fine.
  3. Mar 21, 2012 at 6:41 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Exactly, we'd be like the blind leading the blind in a dark room. On another note, you need to get one of these. The one I have is this exact model, an Actron pocket code reader. If you had one you might have found out that the CEL was something non-essential which it almost always is, and continued on your trip. Plus these are good to have anytime anywhere that way you can always know what's going on with your truck. I keep mine handy in my glove box.
  4. Mar 21, 2012 at 1:00 PM
    theGastone
    Ian
    Leesburg, VA
    '97 Standard
    P0420 and a P0401.
    I know that the P0420 can often times be a load of crap. And I've had the CEL come on for that before. The P0401 however I've not had before so I'm not sure what the deal with that is.
    Now that we know what's probably going on... any ideas on how to fix it?
  5. Mar 21, 2012 at 1:20 PM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    420? You can still drive like that no problem
  6. Mar 21, 2012 at 1:24 PM
    theGastone
    Ian
    Leesburg, VA
    '97 Standard
    It's the 401 I'm worried about. I don't know anything about it.
  7. Mar 21, 2012 at 2:24 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
  8. Mar 21, 2012 at 10:54 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
  9. Mar 22, 2012 at 2:01 AM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    Depending on where you live, a local auto parts store like Auto Zone can lend you a tool to read the code/read it for you .This is all free as well.
  10. Mar 22, 2012 at 5:16 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I know it says 2003 and "only for 3rz-fe" but it's the same procedure that's in the 96 FSM manual for this code.
    http://ncttora.com/fsm/2003/Repair_Manual/03tacoma/di/eg2rzfe3/cip0401.pdf
    Simple things first; look at the hoses for the EGR to make sure they are not cracked, missing, or loose.
    The EGR looks like this and should be on the rear of the head.
  11. Mar 22, 2012 at 6:45 AM
    KenpachiZaraki
    Alex •﹏•
    Lubbock
    If you buy the egr valve, make sure to buy the pressure sensor if it has one. They both work together and I've seen tons of people buy only one and a week later they end up buying the other one either way because the light still came back on. Check your hoses spray some carb cleaner around there and see if the idle drops then rises, you could have a small crack in,one of the hoses that you can't see. Vacuum leaks are a bitch to find, and somethings you end up changing all of them out either way. Good luck OP
  12. Mar 22, 2012 at 9:25 AM
    theGastone
    Ian
    Leesburg, VA
    '97 Standard
    Speaking of which I found a vacuum hose with a particularly large cut in it. So I replaced that immediately. Over the next few days I'm going to Slowly replace all of the hosing.
  13. Mar 22, 2012 at 9:41 AM
    97T
    97T Resident T100 guy
    Melt
    Littleton, CO
    97 T100 xcab 5spd 2wd
    soundstream 550.2 amp, 2 eclipse 10" subs, 4% tint rear window, 20% sides, 6" sunstrip, clear bumper lenses, avital 4103 alarm with keyless, BF Goodrich Rugged Terrain T/A 235/75/15, 15X7 6-5.5 0C Unique 298 rims
    unless you live in california .... bastards cant do free scans anymore
    when i had my 99 mazda my cel popped on during a trip to az ... was already more than halfway there so got it scanned when i got to az ... turned out to be the throttle position sensor .. bought a new one for $30 and installed it at my buddys house and never had any probs after that
  14. Mar 22, 2012 at 10:38 AM
    theGastone
    Ian
    Leesburg, VA
    '97 Standard
    They did for me here in Florida.
