Check engine light w/ the little traction control light came on..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by twistax, Aug 20, 2011.
  1. May 7, 2013 at 11:05 AM
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    It was an oxygen sensor now driving home abs light comes on :s
  2. May 7, 2013 at 1:22 PM
    4banger09
    Alex
    Nb, Canada
    Leveled
    Quoted 400 bucks for o2 sensor installed I found it online for 160 and ill be doing it myself it's just 1 bolt. Abs light went away I disconnected the battery again
  3. May 7, 2013 at 1:37 PM
    97Blk_one
    97Blk_one Well-Known Member
    Memfrica
    not so low
    A whole lot,But not satify
    I was told by a mechanic, if everything running fine, spent $200 to get rid of the "CheckEngine Light " is not worth it, So I drive till the light gone away...that was 5 years ago....
  4. May 7, 2013 at 1:58 PM
    4banger09
    Alex
    Nb, Canada
    Leveled
    The tech told me the truck will run in fail safe mode until the cel is fixed and there would be performance losses
  5. May 7, 2013 at 1:59 PM
    97Blk_one
    Memfrica
    not so low
    You're correct, I would get it taking-care off when you can or ASAP
  6. May 24, 2013 at 7:15 AM
    Rosekate
    Rosekate Newhere
    Rose
    LA,California
    Check engine light may refer some common problem that your car engine might have, like:
    1. Faulty oxygen sensor.
    2. Loose Gas Cap
    3. Catalytic convertor fail
    4. Airflow sensor
    5. Spark plug & wiring
    You can find more information about your check engine light problem at www.hiperformer.com sites engine repair pages and get relevant solutions by experts there.
    LUNCHBOX66 likes this.
  7. May 24, 2013 at 8:09 AM
    4banger09
    Alex
    Nb, Canada
    Leveled
    Just another thought if it is your oxygen sensor don't let the dealer do it, do it yourself it's super easy to change and not worth the shop fees. I also got the same sensor for 250$ when the dealer wanted 314$
  8. Mar 7, 2014 at 7:07 AM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    Bringing this thread back to life, the lights came on. Well looks like I will be reading some codes this morning:annoyed:
    Not new to this shit, just venting because I'm always out money for the fix :mad:
  9. Sep 24, 2014 at 12:40 PM
    bcan87
    bcan87 Member
    Bryan
    Ga
    01 PreRunner White SR5
    Girlfriend has a 2010 Corolla. The Check Engine light is on along with the "VSC off" light flashing. The radio does not work properly either. The display does not work and the radio turns off if you press any button.
    Multiple codes are showing up when you hook it up to the code reader. One code is the P0138 Oxygen Sensor Circuit High Voltage Bank 1 Sensor 1 code. Another code is the P0607 Control Module Performance code.
    Does anyone have any insight into this issue?
  10. Sep 24, 2014 at 1:03 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    And your gas mileage will suck really bad.
  11. Jun 11, 2015 at 9:11 AM
    montgomb
    montgomb Member
    Brent
    2015 Toyota Tacoma Black TRD Off Road Pkg V6
    2015 Tacoma TRD\Off Road @ 600 miles. Lights just came on this morning. Based on this thread I'm going to take it to auto parts store today to see what code it's throwing then to the dealer. It's still way under fact warranty and extended. I'll re-post the results. Thanks everyone!
  12. Jun 11, 2015 at 1:49 PM
    montgomb
    montgomb Member
    Brent
    Autozone looked up the codes (attached). I took it to the dealer (Toyota) and they said that 90% of them time when the evap error occurs it's a faulty gas cap. He reset the computer and said if it shows up again come back. I had a locking gas cap on it that I had on my other car that I was using. I'm guessing that was problem so I switched back to the OEM cap. I hope this was helpful to someone. Peace out...
    Waltsie94 and TRDSport10 like this.
  13. Dec 1, 2015 at 2:59 PM
    itsgeorge
    itsgeorge New Member
    montgomb Did the gas cap solve the issue?
  14. Dec 1, 2015 at 3:14 PM
    montgomb
    montgomb Member
    Brent
    Yes it did
  15. May 25, 2016 at 12:39 PM
    #35
    aquila105
    aquila105 Member
    Emanuele
    Las Vegas
    2009 grey Tacoma double cab, 2wd TRD Off Road, Prerunner SR5
    Got mine after changing wheels and tires...
    VolkswagenTaco likes this.
  16. May 31, 2016 at 1:26 AM
    #36
    wakeupdawn
    wakeupdawn New Member
    2009 Charcoal Tacoma
    09 pre runner... I drove 6 months with Check Engine and skid control light on. Changed fuel cap but lights would still come on and off. Finally light stayed on. Just changed out all the o2 sensors and hope that fixes the problem. If not, it's the Cat converters. Not cheap for the o2 or Cat converter. FYI I have 156,000 miles and that about where these parts start to wear out.
  17. Jul 21, 2016 at 4:46 PM
    #37
    tacoma671
    tacoma671 Member
    john
    GUAM,USA
    2012 tacoma
    So it was only the gas cap which caused the lights go on???
  18. Jan 15, 2017 at 9:31 PM
    #38
    TACOMA 57
    TACOMA 57 New Member
    2012 Tacoma TRD
    Thanks everyone. First stop is dealer.
  19. Feb 19, 2017 at 6:44 PM
    #39
    VolkswagenTaco
    VolkswagenTaco Well-Known Member
    Sean
    Compton
    2012 sr5 4x4 Canadian model with factory locker. Pyrite Mica
    This just happened to me when I changed my tires. What solved your issue?
  20. Jun 28, 2018 at 11:09 AM
    #40
    tgordo49
    tgordo49 Active Member
    Tim
    Boston metro-west
    '15 Black Taco AC TRD Off-Road V6 Tow pkg.
    Spare tire lock, floor mats, UnderCover, P3, V1.
    Same deal: They don't like the replacement locking gas caps. Also happens if you cross-thread it or don't tighten it all the way until it clicks.
