Check engine light went out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Andrewkcrow84, Dec 7, 2023.
  1. Dec 7, 2023 at 2:30 PM
    Andrewkcrow84
    Andrewkcrow84 [OP] Well-Known Member
    Andrew
    Yosemite National Park
    07 TRD
    I had an 06. My check engine light went out and I'm not sure how to fix it. When hooked up to obd everything reads fine, it's just the light that went out. Any ideas on how to fix this? I'm pretty sure this model out isn't just a bulb, it's an led.
  2. Dec 7, 2023 at 2:47 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    So it doesn't come on at all key on engine off?
  3. Dec 7, 2023 at 2:52 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    It’s supposed to be off
  4. Dec 7, 2023 at 3:40 PM
    Avotaco
    Avotaco Active Member
    Eric
    Jersey
    94 PU 4x4 4cyl MT reg cab, 06 Taco 4x4 4cyl MT Acc Cab
    when you turn on the accessory switch with the engine off is the CEL on? if not maybe the bulb just burned out (happened with my avalon).
    PIA as i needed to change the bulb to get the car through state inspection…
  5. Dec 7, 2023 at 4:21 PM
    Andrewkcrow84
    Andrew
    07 TRD
    Correct. It needs to come on to pass smog and it doesn't come on when you turn the key.
  6. Dec 7, 2023 at 4:39 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    It's a simple circuit, single wire running from Connector E7 Pin 30 (Brown) at the PCM through Connector II1 Pin 9 (Brown) behind the right kick panel to Connector C9 Pin 17 (Brown) at the Combination Meter (Instrument Cluster).
    The PCM grounds this wire to turn the light on so you either have an open in the wire, a faulty cluster, or a faulty PCM.
    Key on you can use a test light to ground the wire starting at the PCM and working toward the cluster and see if the CEL illuminates.
    I can post the relevant diagrams and pinouts, do you have the 2.7L 4 cyl or 4.0L V6 engine?
  7. Dec 7, 2023 at 5:50 PM
    Andrewkcrow84
    Andrew
    07 TRD
    I have the 4.0. I have no clue what you're talking about lol.
  8. Dec 7, 2023 at 6:13 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    He means if you ground the wire that goes to the gauge cluster it should turn the light on. He's listing the connectors that the wire goes through on its way from the pcm to the cluster.
    If you ground the wire and the light doesn't come on it likely needs a cluster. If it was a bulb (instead of led) you'd pull the cluster out, flip it over and replace the bulb
  9. Dec 7, 2023 at 6:38 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Grounding the BROWN wire @ pin 9 on the II1 connecter with the ignition ON should illuminate the light.
    Jimmyh, Dm93 and Canadian Caber like this.
  10. Dec 7, 2023 at 6:48 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Thanks for the correction, looks like II1 is on the left side behind the glovebox. May be easier to test at the PCM although unless you have rodents it's unlikely an open wire.
    TnShooter[QUOTED] likes this.
