check engine light
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacoma92, Aug 5, 2010.
  1. Aug 5, 2010 at 7:20 PM
    tacoma92
    tacoma92 [OP] Black Hole Sun
    Forrest
    Gulf Shores, Alabama
    09 SR5 Toyota Tacoma
    my check engine light is bipolar. it comes on and will stay on for a while and then one day out of nowhere it will shut off for a while and then repeat the same process. Any ideas on wat it could be or should i jus get it turned it off permanently? and how would i turn it off?
  2. Aug 5, 2010 at 7:27 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    check the codes
  3. Aug 5, 2010 at 7:28 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Ever changed any of your O2 sensor(s)? Go to an auto parts store and have them pull the codes. The check engine light may only come on when the sensor is operating outside its parameters.
  4. Aug 5, 2010 at 7:35 PM
    tacoma92
    Forrest
    thanks for the advice guys. ill def check tht out
  5. Aug 5, 2010 at 7:41 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    If it's exhaust related, your truck has to complete certain steps when reading the o2 sensors. You have to be driving for 3 miles at a constant speed above 40 mph. Then it scans. So if your o2 sensor is flaky, it will come on when it reads outside the tolerance, but will go off if it reads okay. Assuming it's a o2 sensor....
  6. Aug 5, 2010 at 7:46 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    get the codes read....but in the meantime...check your gas cap. make sure its clicked a few times and tight. may have a faulty seal if not.
  7. Aug 5, 2010 at 11:23 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    you'll probably have trouble codes stored. not much point in guessing till you get the codes.
