check engine light
Discussion in '1st Gen. Tacomas (1995-2004)' started by seancanterbury, Nov 3, 2008.
  1. Nov 3, 2008 at 10:18 PM
    seancanterbury
    seancanterbury [OP] Well-Known Member
    SLC, UT
    02 4X4
    I installed a new Gibson exhaust and k and n intake and my check engine light came on. I called Gibson and they said theyve had reports of the light coming on after the exhaust was installed with an aftermarket intake(something with the mass airflow sensor and the o2 sensor not matching up) he said disconnect the negitive terminal on the battery to reset the computer and the car will eventually learn the code or peramiters of the new system. Doesn't seem to be working to well... Anyone else have any suggestions?
  2. Nov 3, 2008 at 10:24 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    What code is it?
  3. Nov 4, 2008 at 4:49 AM
    4x4Runner
    4x4Runner Now with more Oi Vey! Moderator
    Drunken Sailor
    Somewhere between Maine and Florida
    2017 4Runner Smashed Ass Edition
    KDSS
    Agreed. Get it it read and let us know what the code is.
    Could get a Scanguage, install it and never have to worry about what the pesky code is again. That little toy will read the code and after you've fixed the problem you can clear the code with it.
  4. May 28, 2009 at 5:19 PM
    notslow
    notslow Well-Known Member
    Palm Springs, Ca.
    02 TRD black
    I have the same problem. I installed a Gibson cat back and AFE dryflow for the stock airbox and did the airbox mod. Not sure the code number, a friend checked it, but the code was for catalytic converter not to spec. I have reset it a few times but it comes back. Maybe space out the 02 sensor past the cat?
    Will
  5. Jul 29, 2009 at 10:09 PM
    yamahamod
    yamahamod Active Member
    Korey
    Colorado
    06 Tacoma SC w/total chaos & King shocks
    Anybody have the damn battery light come on?
    Mine comes on whenever it's chilly or I wash under the hood? wtf
    O and my tire light is for ever on to. All my tires are fine.
    06 supercharged tacoma with piaa lights and lights in my ARB.
    I never have any problems starting or anything else.
    Give me your .02
    Not to steal your thread or anything there wasnt one for the battery light.
  6. Jan 14, 2010 at 8:55 PM
    notslow
    Palm Springs, Ca.
    02 TRD black
    Still never figured out the check engine light. Got the Gibson exhaust and ever since the check engine light comes on every few weeks. I've noticed it only happens when I'm cruising with very light throttle, low RPM. The code is for o2 sensor. I know I didn't damage it and I didn't use wd-40 or anything that would mess it up. Any ideas?
  7. Jan 22, 2010 at 7:08 AM
    Gwest1967
    Gwest1967 Active Member
    Gregg
    S.E. Kansas
    SR5 V6 4x4 Ext Cab
    16 inch tires/wheels
    I bought my 2001 Tacoma V6 5spd on Labor Day 08. A few weeks after the engine light came on.. I reset the computer, and since then cut a 2x4 hole in the air box to give it more air.. Well I just read the post on the MAF sensor and thought I would check into it, and was surprised the little burger was really dirty.. I used a carb cleaner on it and it seems to work better now, because the performance is better... I hope this also improves my mileage, its been 17 mpg or worse since I bought it...
  8. Jan 22, 2010 at 7:12 AM
    Gwest1967
    Gregg
    S.E. Kansas
    SR5 V6 4x4 Ext Cab
    Don't feel bad about the tire light.. It is a toyota thing.. I have seen the light come on in my buddies Toyota Van, and also in anothers Camry.. No problems with the air pressure.. Just a glitch.. I am glad my 01 doesn't have it..
  9. Jan 22, 2010 at 4:12 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    We have tire lights?
  10. Jan 22, 2010 at 5:45 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I would first clean the MAF sensor, those get prety dirty if not maintained.
    And if that doesnt help, I would check the o2 sensors, bc with the new air flow the sensors could be reading differently...
