check engine light
Discussion in '1st Gen. Tacomas (1995-2004)' started by 99YOTA412, Dec 8, 2011.
  1. Dec 8, 2011 at 5:37 PM
    99YOTA412
    99YOTA412 [OP] Active Member
    layton
    south carolina
    06 Tacoma TRD Offroad, Bilstein 5100 shocks
    hey guys, my check engine light came on so i took it to autozone to get them to scan it. the code came back as a p0446 code and i want to know how to go about fixing that
  2. Dec 8, 2011 at 5:41 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
  3. Dec 8, 2011 at 5:43 PM
    Manwithoutaplan
    ID
    Evaporative emission control system vent control circuit fault.
    there is a electrical solenoid (evap solenoid valve)mounted on the fuel vapor canister this it what is wrong,some times you need to replace canister also it will get saturated with fuel because valve is not working properly
  4. Dec 8, 2011 at 5:45 PM
    Manwithoutaplan
    ID
  5. Dec 8, 2011 at 6:01 PM
    99YOTA412
    layton
    south carolina
    thanks how hard is that to fix?
  6. Dec 15, 2011 at 12:29 PM
    FettsVette
    FettsVette Member
    Albany
    02 Tacoma SR5
    Hey man, don't know what motor your runnin, but I have a '02 3.4 and my (dreaded) cel was on, throwing 6 codes 2 each of p0441,p0442, and p0446, all evap stuff. Figured I'd start with the gas cap and it worked. Got a stant one from napa for about 10 bucks. So before you go messing around with the vsv's or that 200+ evap canister from the dealer, you might wanna give that a shot!
