Check engine light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma414, Mar 30, 2012.
  1. Mar 30, 2012 at 7:14 PM
    Tacoma414
    Tacoma414 [OP] Well-Known Member
    Cody
    Agua Dulce
    06 PreRunner SR5 4.0L
    Flowmaster Exhaust 2" spacer lift 09 Tails blacked out Black headlight mod 6000k HIDs/Foglight mod Fog Light Mod 20" LED Light Bar Behind Grille Billet Grille Color matched mirros, doorhandles and bumper 5% tint all around Pioneer 4300dvd 2 10" kicker CVRs Alpine speakers Dome light: Blue LED Map light: White LED
    So I'm working and it comes on, I'm only at 86,947, and it's serviced regularly, I know I need a new air filter and my next oil change isn't Til 90,000, any ideas what it might be? Thanks
  2. Mar 30, 2012 at 7:16 PM
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    check the gas cap, make sure its tight.... reset the ecu ( disconnect the battery for a few minutes).... If it comes back on get it scanned
  3. Mar 30, 2012 at 7:20 PM
    Tacoma414
    Cody
    Agua Dulce
    I was going to take it to a local shop but it's gonna cost me a lot more then borrowing one, I'll get it scanned tomorrow and post it
  4. Mar 30, 2012 at 7:33 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Its worth buying a pocket scanner for just this thing. $40 from harbor freight or $60 for the orange actron which can be found anywhere. If you pull the negative battery cable for a reset, you'll erase your fuel trims as well as a bunch of other diagnostics which are based off a certain number of drive cycles.
    My wife's corolla with 135000 miles kept throwing codes, and I was able to narrow down with the codes that were thrown to a common intake manifold gasket problem and fix it.
    My next venture is a toyota techstream mongoose cable + techstream 7 software....I can check on everything on all 3 of our Toyotas :)
