check engine light?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sturg, Sep 13, 2007.
  1. Dec 17, 2007 at 7:41 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  2. Dec 18, 2007 at 6:34 AM
    A1CGuches
    A1CGuches Oregon Alliance: Founder
    DMAFB, Arizona
    01 Taco
    Custom snorkel/intake, 6" lift, 35X12.5 mt's, flowmaster 40 seriers, performance clutch, custom skid plate, grille, everything is black on green, rotrex supercharger, 7th injector kit, urd short throw shifter, thorely header, kks speed limit defender...and more to come
    Thanks i am definetly goin to do that
  3. Dec 26, 2007 at 10:39 AM
    96Tacoma4x4
    96Tacoma4x4 Well-Known Member
    Memphis, TN
    96 xcab 4x4 LX stock
    32x11.50 and K&N filter drop in
    My light comes on every now and then, Auto Zone told me the samething about my O2 sensor throwing a code. Guy told me to run some Premium gas in it, bingo solves my problem everytime it comes on. He also told me its that cheap ass gas (like corner mom & pop, aribian stores) that causes the light to come on, it's a low grade of gas. Now I have been running like BP or Shell regular gas and the engine light has not come on in the last 6 months. I've never cleaned or replace any of my sensors (original ones) and got 200,000 miles.
  4. Dec 26, 2007 at 3:14 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    The CEL not coming on doesn't mean you don't still have a problem. The codes could still be stored in the computer. FWIW, I've never heard of bad gasoline causing a CEL.
  5. Feb 15, 2009 at 7:29 AM
    Johnny Monsoon
    Johnny Monsoon Member
    Dallas
    LX 4x4
    Where's the reset button (if there is one) for the check engine light for scheduled maintenance. I just rolled past 140K on my truck and the light came on. I don't think its coincidence that this just happened to occur as the timing chain is due for replacement.
    Any help?
  6. Feb 15, 2009 at 7:46 AM
    98tacoma27
    Ben
    Not Beech Creek
    According to your profile you have a 1995, correct? There is no reset button for this or a maintenance light. Just the check engine (CEL) light. You will have to get the code read and go from there.
  7. Feb 15, 2009 at 7:48 AM
    Johnny Monsoon
    Dallas
    LX 4x4
    Drat. Well, thanks for the prompt help!
  8. Feb 15, 2009 at 9:06 AM
    DefyInertia
    DefyInertia Saratogian
    Nate
    NorCal
    '05 DCLB 4x4 SR5#8 (white)
    Toytec Ultimate: ~3" up front via coil overs, LR UCAs, and SB delete; 2+ out back with AAL and new shocks. Leer cap, padded sleeping platform in bed
    unplug the battery...doing so will get rid of the CEL. If it comes back on, then you know you need to check the code (I'd check it first anyway though).
  9. Feb 15, 2009 at 1:33 PM
    ILove2Drive
    ILove2Drive Well-Known Member
    Casey
    WV
    07 Tacoma 4X4 5 Speed Manual
    Halo headlights, Black tail light covers, dual exhaust, 5100s front and rear, eibach coils, wheelers 1.5 AAL, window tint, bow arrow antenna, bull bar, painted grille emblem, debadged, raceline rims, a few decals, CB radio, alpine HU, husky floor liners, tool box, mesh grill...and more to come eventually
    My engine code is P0141 and it is coming from Bank 1 Sensor 2. Is this something that can be easily repaired on your own, or better to take it in to the dealer?
  10. Feb 15, 2009 at 2:14 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    Read up here, I didn't find Tacomaworld before I had this problem...but through the internet I found the problem...the maf sensor was fuzzy with dust,debris. Buy a can of maf, back then it was electrical parts cleaner, remove the maf, spray the hell out of it, I used almost a whole can, it should look like a small coil with a hair of a wire when clean, it will evaporate(the cleaner) on it's own. Put it back in take the neg. of the battery and pull the main fuse. In 5 minutes, replace the fuse, then the battery and start. My 99 3.4 gave me the same code, once I did this it was good to go. Now if the light goes out and your gas mpg still is in the crapper, then "look" into a o2 sensor, either one of them. Kevin and it worked for me.
  11. Feb 15, 2009 at 2:17 PM
    98tacoma27
    Ben
    Not Beech Creek
    Yes you can repair this on your own. That is the O2 sensor. It will be right behind the CAT. You can get the OEM replacement at URDUSA.COM.
    scottalot likes this.
  12. Dec 20, 2009 at 6:09 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    the maf bulb is very brital, just let er dry naturally instead of wiping it down. If ya break that then ur really screwed
  13. Jan 22, 2010 at 7:14 AM
    Gwest1967
    Gwest1967 Active Member
    Gregg
    S.E. Kansas
    SR5 V6 4x4 Ext Cab
    16 inch tires/wheels
    Thanks for the info.. I cleaned mine and it helped in the way it ran... I have a 5 spd and it was doggy in the middle of 3rd, and now it isn't.. Thanks again...
  14. Jan 22, 2010 at 12:33 PM
    DaytonLax14
    DaytonLax14 Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    my CEL has been on for the past couple months and when I unplugged the negative battery terminal to install some off road lights, the light hasn't come on yet, but it's only been a day.
  15. Jan 22, 2010 at 3:15 PM
    #35
    humanoid
    humanoid bite me
    Sunny SoCal
    You may have cleared the light, but the code may still be stored in the computer. Don't you want to figure out what's causing the CEL rather than just forgetting about it? Running with a code is always a bad idea because you don't know how serious the problem is.
  16. Jan 22, 2010 at 7:47 PM
    #36
    DaytonLax14
    Corey
    Ohio
    I do know what the code is for, a cracked exhaust manifold.
  17. Jan 22, 2010 at 7:57 PM
    #37
    humanoid
    humanoid bite me
    Sunny SoCal
    So you're going to leave it then because you have no CEL?
  18. Jan 22, 2010 at 8:01 PM
    #38
    DaytonLax14
    Corey
    Ohio
    No...? Why are you making assumptions?
    The mechanics said it's nothing I have to hurry to get done and will drive and run just fine for a long time. I'm getting it fixed when I have 300 bucks saved up or I might just get some headers.
  19. Jan 22, 2010 at 8:03 PM
    #39
    humanoid
    humanoid bite me
    Sunny SoCal
    Well, you've mentioned nothing about those things that I asked in your previous postings, that's why I asked. Sheesh....
  20. May 2, 2010 at 9:15 AM
    #40
    ianc
    ianc Well-Known Member
    ian
    mass
    tacoma sr5 trd
    The only time you can run of the O2 sensor is bad if its the heater. If the O2 sensor portion is bad you will fry you plugs your cat and wash down cyinder walls. No input for O2 means no Hydrocarbons=no fuel . Computer will keep dumping fuel in until it sees voltage. But the voltage will never be produced if sensor is not working. Pretty exspensive fix. Replace the O2.
    Yes you had probaly do it. 7/8 Wrench or O2 soket. and possibly a torch. Use more anti sieze on the way in and do not put any electric gel on the connector, they are suppose to be dry.
    Hamer95USA likes this.
