check engine light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jwbartels40, Feb 20, 2015.
  1. Feb 20, 2015 at 9:23 AM
    jwbartels40
    jwbartels40 [OP] New Member
    fort myers fl
    06 pre runner
    After changing my oil how do i reset the check engine light
  2. Feb 20, 2015 at 9:34 AM
    fizik
    fizik Accidental Offroader
    Minnesota
    '13 DCSB SR5, '10 DCSB TRD OffRoad (deceased)
    Check Engine is not the oil light. If it is your check engine light, then you probably do need to take it into your dealer. Or at the very least, get a ODB scan code device (or bluetooth adapter for your smart phone) to retrieve the code and see what the problem is. Most scanners will allow you to clear the code to and reset the check engine light.
    You can reset the "MAINT REQD" light after changing your oil (from the manual, section 4.2 Maintenance):
    Reset the maintenance data (U.S.A. only)
    After the required maintenance is performed according to the maintenance
    schedule, please reset the maintenance data.
    To reset the data, follow the procedures described below:
    Switch the display to the trip meter A when the engine is running.
    P. 155)
    Turn the engine switch to the LOCK position.
    While pressing the ODO/TRIP button (
    P. 155), turn the engine
    switch to the ON position. Continue to press and hold the button
    until the odometer displays 000000.
    jeratbp, tonytsai0429 and Justus like this.
  3. May 18, 2015 at 1:38 PM
    tonytsai0429
    tonytsai0429 Well-Known Member
    SoCal
    Racy Inferno
    this is very helpful!!
    thanks!
  4. May 18, 2015 at 4:15 PM
    tonytsai0429
    SoCal
    Racy Inferno
    that is very interesting...i will follow through with this....
