Check Engine Light
Discussion in 'Toyota Trucks & SUVs' started by awanaw002, Nov 4, 2015.
  1. Nov 4, 2015 at 9:03 AM
    awanaw002
    awanaw002 [OP] Member
    Aloha! My check engine light is constantly on. I went to the dealers and they told me it was O2 sensor. When I asked them what that was, they said my catalytic converter is failing. This would big a out off pocket expense. Is this true for Tacoma trucks with 143k? A less expense remedy would be appreciated.
  2. Nov 4, 2015 at 9:05 AM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    replace the O2 in question and see what happens. They go bad sometimes
  3. Nov 4, 2015 at 10:49 PM
    AlexiMikalov
    AlexiMikalov Member
    I'm having this same problem right now, with similar mileage. Did they say it was a P0420 code? If it is, all my research has found it could be a dozen different things. From something as inexpensive as a new gas cap to needing a new catalytic converter. I've tried a bunch of things and looked at live data on an OBD II scan tool. It's looking like cat may be bad.
    I would not trust the dealer or just replace the sensors. I replaced the upstream one years ago and it fixed the problem, this time it did not work. Get a scan tool tool and look at the live data of your sensors. If it shows they aren't working then I'd replace them, otherwise I'd look elsewhere for the problem.
  4. Nov 4, 2015 at 11:26 PM
    Vang Toua Moua
    Vang Toua Moua Well-Known Member
    Vang Bang
    Visalia, CA
    05 Silver Tacoma 2.7, Access cab, 5 lug
    Custom front bumper and rock sliders, glasspack muffler, shorten exhuast, abs killswitch, roof light bar, rear e locker.
    I'm having similar issues. I already tried replacing sensor, manifold, and repair a crack I had. Still nothing, but on my taco I'm getting no reading on my upstream.
    I'd suggest check that out. That's what imma be doing for mine.
