Check engine light
Discussion in '3rd Gen. Tacomas (2016-2023)' started by thomasr1950, Aug 19, 2016.
  1. Aug 19, 2016 at 9:55 AM
    thomasr1950
    thomasr1950 [OP] 19 Tacoma TRD Off Road
    central us
    After getting gas my check engine & traction light came own. Dealer said it was water in gas, the code was for the catalilytic converter. Gas station said no one else had issues. After Dealer reset code the next day it came on again. Anyone have a idea what the cause is?
    ChadsPride likes this.
  2. Aug 19, 2016 at 9:56 AM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Any mods done to power train? Sounds like you need to drain out the gas before you harm something.
  3. Aug 19, 2016 at 9:57 AM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    Water in the gas :notsure:, station would never admit to it.
    specter208 and Lawfarin like this.
  4. Aug 19, 2016 at 9:57 AM
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Crank position sensor gets my vote.
    Mike O and bobrown14 like this.
  5. Aug 19, 2016 at 9:58 AM
    swimmer
    Tucson
    2016 TRDORAC4WD
    OP, when did you buy your truck? Do you know build date?
  6. Aug 19, 2016 at 9:59 AM
    Gander
    Gander Well-Known Member
    Ellis County Texas
    2012 TRD 4x4 Tacoma
    how did dealer determine water was in the gas?
  7. Aug 19, 2016 at 10:00 AM
    Clearwater Bill
    Billy
    Largo Florida
    Tell us the code(s) that was pulled.
    BTW, there is no code for impure gas. There might be other codes to be set that it could cause, like random misfire and such.
    Someone is blowing smoke up your skirt.
    Aussiek2000 likes this.
  8. Aug 19, 2016 at 10:00 AM
    COskimtb
    COskimtb Well-Known Member
    25 Sequoia TRD Pro
    Did you tighten the gas cap so it clicked?
  9. Aug 19, 2016 at 10:01 AM
    98tacoma27
    Ben
    Not Beech Creek
    I think they bypassed the skirt and went straight for his ass
  10. Aug 19, 2016 at 10:01 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    All out of popcorn...
  11. Aug 19, 2016 at 10:02 AM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Just got gas and light comes on. My vote is for gas cap not seated.
    specter208, angry john, Joe23 and 5 others like this.
  12. Aug 19, 2016 at 10:03 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    This just happen to my 15 deeler is telling me it my ECU truck is still under warranty
  13. Aug 19, 2016 at 10:04 AM
    Clearwater Bill
    Billy
    Largo Florida
    And apparently still not seated, since it came back already. But I'm sure the dealer would have done that for him, right? I mean how else did he discover water in the gas.........
  14. Aug 19, 2016 at 10:05 AM
    thomasr1950
    central us
    The Dealer said the code was for catalitic converter. He advised to run the gas out, fill up again. If light stays on he will check further. I did loosen the gas cap & retighten, stayed on. After the dealer checked it yesterday it went off, then today after driving for 15 min, the light came back on.
  15. Aug 19, 2016 at 10:06 AM
    thomasr1950
    central us
    Well if so its under warranty. So it didn't hurt.
    98tacoma27[QUOTED] likes this.
  16. Aug 19, 2016 at 10:06 AM
    daddy_o
    Bossier City, La
    A loose gas cap will show emissions code. Its easy for dealer to just say, yep, water in gas, especially if customer states he just got gas. I doubt they even removed the cap and retightnened it. Just reset code and let him go.
  17. Aug 19, 2016 at 10:08 AM
    tacos_modern_life
    tacos_modern_life Well-Known Member
    Brandon
    Portland, OR
    2015 Inferno TRD Pro
    TRD S/C, afe/TRD intake, TRD exhaust, Work Meisters, Retrax, Baja Designs Amber Fogs
    I'm with this guy
  18. Aug 19, 2016 at 10:10 AM
    thomasr1950
    central us
    Code says found cat. Conv codes. All test OK, test drive and monitor passed.
  19. Aug 19, 2016 at 10:10 AM
    Clearwater Bill
    Billy
    Largo Florida
    Bingo! (you couldn't see my tongue in cheek before)
    Gander likes this.
  20. Aug 19, 2016 at 10:14 AM
    daddy_o
    Bossier City, La
    If there is a problem with the O-ring on the cap the code will come back. I am not sure if Toyota uses the same sequence, but my dodge needs to see the issue correct for three run cycles before completely dissappearing, unless issue is resolved and code reset by scan tool.
