Check engine light
Discussion in '3rd Gen. Tacomas (2016-2023)' started by thomasr1950, Aug 19, 2016.
  1. Aug 19, 2016 at 10:14 AM
    Clearwater Bill
    Billy
    Largo Florida
    The code numbers. Not what they told you the interpretation of the numbers were...........
    AFAIK a scanner test drive and monitor doesn't replicate x keystarts, or other things that create pending codes vs displayed codes.
    So. If you believe the water in the gas story, get some gas dry at the parts store and toss it in the tank. Along with a top up of fuel from another location. Code should not return once you clear it this time. (DIY by battery ground removal if you don't have a scan tool)
  2. Aug 19, 2016 at 10:38 AM
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    The code was for cat converter, we've seen this code before for people with a bad CPS. Why the love for loose gas cap? Even the most clueless tech would know to check the gas cap.
  3. Aug 19, 2016 at 10:45 AM
    Qwntm
    Qwntm Well-Known Member
    Edward
    Boise, ID
    2016 Inferno TRD Off Road DCSB
    None...yet!
    Doesn't CPS failure cause the truck to not run? If there is a check engine light, but the trucks running fine, then not the CPS I would think. Or have there been cases of the CPS going out and the truck running fine?
  4. Aug 19, 2016 at 10:53 AM
    swimmer
    Tucson
    2016 TRDORAC4WD
    Yes, just thinking he's got some sort of issue with the CPS as the gas cap is easily checked and the water in gas explanation seems BS.
  5. Aug 19, 2016 at 11:27 AM
    thomasr1950
    thomasr1950 [OP] 19 Tacoma TRD Off Road
    central us
    Yes
  6. Aug 19, 2016 at 11:28 AM
    thomasr1950
    central us
    Truck runs fine
  7. Aug 19, 2016 at 11:29 AM
    thomasr1950
    central us
    Thete wasn't any codes on the receipt.
  8. Aug 19, 2016 at 11:58 AM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Converter codes would be po420 or p0430. Stop at an auto parts store and have them see what code in in it for shits and giggles. Gas cap would be p0456,455,440
  9. Aug 19, 2016 at 12:00 PM
    thomasr1950
    central us
    Thanks, I'll do that. The dealer didn't put the codes on my receipt.
  10. Aug 19, 2016 at 12:42 PM
    TRDTacoma0817
    TRDTacoma0817 Well-Known Member
    Virginia
    Modern gas pumps do an excellent job of keeping water out of the system. Sounds like the tech was being lazy.
    Joe23 likes this.
  11. Aug 19, 2016 at 2:18 PM
    Aussiek2000
    2016 Offroad AC
    not too good of a job. Tech next to me just had to drain a tank in a van. 1/2 the tank was water.
  12. Aug 19, 2016 at 4:18 PM
    Qwntm
    Edward
    Boise, ID
    None...yet!
    For sure... It's possible the CPS is starting to go. Water in the gas has a probability of about zero %. :) (Well, I guess it's possible.)
    I'd start by trying a different gas cap. I bought the locking one at Walmart and it's working so far. Not a bad cheap mod anyway.
  13. Aug 19, 2016 at 5:24 PM
    swimmer
    Tucson
    2016 TRDORAC4WD
    Hope that fixes it.
  14. Aug 19, 2016 at 6:34 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    If the dealer thought the gas was the issue. What did they do to resolve the issue besides resetting the check engine light?
  15. Aug 19, 2016 at 6:39 PM
    #35
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    They told him to run the gas out and see if the light comes back on.
    Lazy tech.
  16. Aug 19, 2016 at 6:40 PM
    #36
    Oiefisherman
    Oiefisherman Well-Known Member
    2014 Ram 3500
    I'm picky about where I purchase fuel for this reason.
    Aussiek2000[QUOTED] likes this.
  17. Aug 19, 2016 at 6:42 PM
    #37
    Herniator
    Edmonton
    Exactly. Lazy tech. Give the customer truck back after telling him he has bad gas knowing that it could do damage to the truck.
    Reasons like this is why I always use top tier gas.
  18. Aug 19, 2016 at 6:43 PM
    #38
    Aussiek2000
    2016 Offroad AC
    Was the customer paying to drain the tank and flush fuel system? It's not a warranty concern
  19. Aug 19, 2016 at 6:45 PM
    #39
    Herniator
    Edmonton
    OP didn't say if they offered to do that. But I think that they should have at least offered him the opportunity and tell him the risks of not having it drained.
  20. Aug 19, 2016 at 6:46 PM
    #40
    Aussiek2000
    2016 Offroad AC
    I agree with that
    Herniator[QUOTED] likes this.
