Check Engine Light
Discussion in '1st Gen. Tacomas (1995-2004)' started by philmdnls, May 23, 2017.
  1. May 26, 2017 at 7:18 AM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    I just did my AFR, go Denso instead of Bosch. Denso OEM's a bunch of stuff for Toyota. I have heard some iffy things about the Bosch sensors. Plus you can get them on Amazon w/Prime shipping for about $80-$100 a piece.
    Also, at least for my AFR sensor, the Denso came with the gasket you need and the Toyota one does not, and cost like $40 more
  2. May 26, 2017 at 7:35 AM
    philmdnls
    philmdnls [OP] Well-Known Member
    Philip
    NC
    2004 Black Double Cab 4x4
    If that happens to be the case I'll definitely look into that. Luckily my sister forgot to cancel her free trial for Amazon Prime so I'll be able to take advantage of that shipping. :D
    Captain Magma[QUOTED] likes this.
  3. May 26, 2017 at 9:55 AM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    I've heard if you get a generic sensor the length of the wire might be longer than factory contributing to higher resistance & erroneous readings. I usually try and buy aftermarket if the factory part is substantially higher.
  4. May 26, 2017 at 10:01 AM
    philmdnls
    Philip
    NC
    I'm taking the truck to the local dealership after I get out of school to see what it is specifically. Hopefully I won't have to buy anything extra other than the muffler already on its way.
  5. May 26, 2017 at 10:45 AM
    Captain Magma
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    If it is in fact one/both of your O2 sensors, give them your VIN and get the part #'s for the ones you need. Then check eBay or Amazon, the dealer near me wanted about $440 for my AFR and O2 sensor, you can get both OEM for like $150 if you shop around, possibly cheaper if you just have 2 O2 sensors
    My part #'s were:
    AFR: 234-9001
    O2:
    234-4189
  6. May 26, 2017 at 12:43 PM
    misteroldschool
    misteroldschool Well-Known Member
    98 4x4 2.7l
    i had a check engine light go on and off on me for a while. eventually it stuck and read as P0401 EGR insufficient flow, turns out the EGR vacuum modulator was bad.
  7. May 26, 2017 at 1:04 PM
    philmdnls
    Philip
    NC
    Thanks for your advice and input guys! I'm currently getting the truck checked out now. I'll let y'all know.
  8. May 27, 2017 at 6:34 PM
    toyrunner
    toyrunner Puddle Jumper
    Danny
    Pasadena, Ca.
    2004 4X4 Tacoma TRD Xtra Cab
    Kings in front, Bilstien Reservoir rears, Custom sway bar disconnects, 265/75 16 BFG AT's, ARB front bumper and FROR rear bumper. Bao-Feng 2 meter radio and Cobra CB
    I just bought the Denso AFR and O2 sensor off Amazon for $150 and change shipped. My O2 sensor is weak and I figure with the cost, do both. Good luck with your issues.
  9. May 27, 2017 at 7:50 PM
    philmdnls
    Philip
    NC
    Update on the check engine light:
    A day late doing this but I'll still do it. Yesterday I brought my truck to the local Toyota dealership and had them check it out. I informed the man that worked with me that there was a hole in the muffler and a new one was on the way after he asked me a few questions and then I went to the wait room while it was being checked out. About 15 minutes later, he calls me back to the payment area and told me that it was sensors in the catalytic converters being tripped. Because of the age of my vehicle they aren't able to tell me exactly which one it is. After he said that, he then followed up by saying that the hole in the muffler is a lot bigger than he thought at first, and that it could in fact be a cause of the check engine light because it was causing there to be no back pressure in the exhaust system. He then told me that wait until I get the new muffler on, and if the light comes back on before I get it on, to just drive with it regularly. Once I get the new muffler in I can bring the truck back in and they'll clear the code for me. If it comes on after the muffler gets installed then I can come back in and they'll check the cats. Today the light came back on after they cleared it to make it go off yesterday. I'll drive with it and get the new muffler on, get the light cleared, and keep this updated if it comes back on afterwards. Thanks for reading, I know it was a little long.
  10. May 28, 2017 at 9:43 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Surprisingly, that sounds like solid advice from the tech at the stealership. Okay, okay. Maybe not that surprising, but kinda is. Thanks for the follow-up. Keep us posted after the muffler goes on.
  11. May 28, 2017 at 11:04 AM
    philmdnls
    Philip
    NC
    Will do. It's driving fine right now. No change in performance except it idles at a little bit lower rpm.
  12. May 28, 2017 at 11:32 AM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    X10!!
