Check Engine Light
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SithLord29, Apr 27, 2021.
  1. Apr 27, 2021 at 4:22 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    magic
  2. Apr 27, 2021 at 4:24 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Tech probably forgot to plug a purge line in. I bet AA cleared it and once the truck runs an EVAP test tonight, it'll pop the code again.
  3. Apr 27, 2021 at 4:40 PM
    TacoMike
    TacoMike Well-Known Member
    Pennsylvania
    '19 SR AC Utility 4x4
    The truck will run fine. Chances are you're gonna get another CEL. Take it back tell them it had a Evap code thrown. It's on them to fix it. Been there done that. Not a big deal.
  4. Apr 27, 2021 at 4:53 PM
    SithLord29
    SithLord29 [OP] Active Member
    2018 Tacoma SR5 Double Cab V6
    Black Exhaust Tip Running Boards Rugged II Tonneau Cover WeatherTech Floormats
    I’m just going to do it when I’m off this Thursday. I just personally hate going to the dealer and waiting.
  5. Apr 27, 2021 at 4:55 PM
    TacoMike
    Pennsylvania
    It is what it is. Request a loaner, my dealer gave me one. A TRD Offroad was my loaner.
    shakerhood likes this.
  6. Apr 27, 2021 at 4:56 PM
    TacoMike
    Pennsylvania
    I dropped my truck off after work in the evening and picked it up the next evening.
  7. Apr 27, 2021 at 6:26 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    old man dummy here, what is CEL?
  8. Apr 27, 2021 at 6:32 PM
    JmsWms
    JmsWms Well-Known Member
    Jim
    Tennessee
    2017 Inferno TRD Sport AC 4x4
    Check Engine Light
  9. Apr 27, 2021 at 6:56 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    so what's the difference from the orange triangle with ! in it?
  10. Apr 27, 2021 at 7:08 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    The triangle is a maintenance light that comes on at normal intervals as well as displays warnings such as the windows being left open, etc. The check engine light talks about actual issues with the vehicle interrupting normal operation in some way (even if you don't notice any difference).
  11. Apr 27, 2021 at 7:09 PM
    RedWings44
    Michigan
    Generally there aren't symptoms with that one. It's more of an emissions thing.
    ktbell444 likes this.
  12. Aug 3, 2021 at 12:46 PM
    KingZee
    KingZee Well-Known Member
    Z
    Los Angeles
    2018 TRD OR
    Bootleg Pro Grill / 16” SCS Ray 10 Black / 265/75/16 KO2s / Voodoo 10” Rack / DA Warrior XL
    I just had this same exact thing happen to me after CA basically forced me to get the recall done so I could renew my reg because “emissions”. @SithLord29 Did you end up taking it to the dealer or did the CEL never come back?
  13. Sep 20, 2021 at 8:36 PM
    KingZee
    Z
    Los Angeles
    2018 TRD OR
    Wanted to update this thread for anyone else that runs into this in the future. I took the truck to the dealer and health check found codes p04417e, p04419c and p045500 all relating to evap leak. Inspection found that vent hose was not secured properly. Tech re-secured and ran evap system check and found no leaks present after repair. Check engine light is gone, it's been a few weeks. If anyone else runs into this it's probably not a big deal, dealer just forgot to tighten up one of the connections.
    MIDTNTACO, JmsWms, ktbell444 and 5 others like this.
